H3 wiring harness
Old Mar 22, 2020 | 08:36 PM
Heebie3's Avatar
Default H3 wiring harness
Hello,
I just installed a different engine and wiring harness in my HT3. Everything went fine except that the new wiring harness doesn't have a plug in for the front differential. The vehicle runs fine but as expected, I have a service 4 wheel drive message. Can I wire a plug in into the harness?
Thanks,
Heebie
Old Mar 22, 2020 | 10:34 PM
you can pull it out of the old harness and pin it into the new engine harness connector. just run it in its own wire loom run it along, and zip tie it to the new harness.
Old Mar 23, 2020 | 08:21 AM
Heebie3's Avatar
Thank you very much. Now I just have to figure out how to do it.
Heebie
Old Mar 24, 2020 | 12:01 AM
start at the front diff plug you need and work your way to the main harness.
that will give you a general idea of how to de pin
Heebie3
Hummer H3T
Mar 24, 2020 06:43 PM
68Thunder427
Mar 12, 2017 11:30 AM
spb4444
Oct 25, 2013 03:20 PM
Deputyj
Sep 16, 2013 06:06 PM
winston44
Mar 10, 2010 11:23 PM
