New H3 Owner Wiring Harness Issues
Old Mar 6, 2017 | 08:31 PM
68Thunder427's Avatar
Default New H3 Owner Wiring Harness Issues
New to the forums here. I just acquired a 2006 h3 and a rat got into the wiring harness at the driver front side , in front of the fuse box, and chewed it to pieces. I have tried finding a decent wiring diagram that lists what the actual harness is called. I am looking for the harness that goes from the connector out to the headlights etc looks like at least a 24 pin connector.
Old Mar 8, 2017 | 10:16 AM
Welcome to HF.
This was MOVED because the New Member section is NOT for tech questions. Questions about H3s go in the H3 section. Crazy how that works, but you should get some help here.
Go to any online seller of GM parts and search, most have diagrams and PNs.
Old Mar 9, 2017 | 07:13 AM
AZ Solar Flare's Avatar
Default Ditto
I have the same issue, except mine is the harness above the transmission.
I recently had a thread addressing my back up lights where I found a shorted wire due to the loom material deteriorating away.
I was wondering if it might be easier for me to replace than to repair??
I too, can't find any parts breakdowns for harnesses
Hope we get a response, good luck to you.
Old Mar 12, 2017 | 11:30 AM
I was able to find the new harness from the connector out, my question is on the engine harness side there are several wires that are the same color and how do I know which is which to splice back the engine harness side of the wiring?
summit
Oct 10, 2010 06:46 AM
winston44
Mar 10, 2010 11:23 PM
CGENERAL
Apr 9, 2008 05:22 PM
dwaxman1
Apr 3, 2008 10:15 AM
SeaGar
17
Apr 3, 2007 03:40 PM
