key wont turn
Old Nov 13, 2008 | 04:48 PM
taz7593's Avatar
Default key wont turn
ok so I went to start my hummer today and the key wont turn. I mean this booger won't budge at all. it is not stuck in the ignition. I can take the key out and put it in but it will not turn. I didn't have any problem with it when I got home last night and shut her off. I am at a loss any ideas?
Old Nov 13, 2008 | 06:49 PM
bflorin's Avatar
Default RE: key wont turn
pull on the steering wheel both ways a bit. Never happed to me in my h2, but did often in my jeep. Does that if you park w/ your front tires against a curb or parking stop sometimes..
Old Nov 13, 2008 | 07:40 PM
huntier's Avatar
This has happened to me with my car. You will most likely need to have the ignition cleaned, might have dust build up. If your Hummer dealer will not do it, (they might want to charge you for a new one) call a locksmith and they will take it out and clean and fix what needs to be replaced all this for more then half of what a dealer will charge. I had a local locksmith do my and I never had another problem with it. Worked like a champ.
Just a thought.
Have a great day!!!
Samantha Waggoner
Old Nov 16, 2008 | 08:44 AM
You could have a dead battery, or a shorted cell. Check the battery. The PCM controls ignition function so if crooks tamper with the voltage to steal it, the key lock to prevent the wheel from being turned.
Old Nov 18, 2008 | 01:33 PM
Gooch's Avatar
Make sure the shifter is all the way in the park position...jiggle the wheel back and forth
Old Nov 18, 2008 | 01:37 PM
Gooch's Avatar
Come to think of it...the same thing happened to me when the battery died.
Old Nov 18, 2008 | 02:01 PM
bflorin's Avatar
yea, that pisses me off when I'm running the radio for an extended time w/ engine off and the battery gets below a certain voltage, locks the damn key in the ignition in on position.
simota1
Nov 24, 2021 12:45 PM
hmer
Nov 13, 2015 08:42 AM
omarluna2
Nov 11, 2014 09:01 AM
Alex2012
Jul 12, 2012 06:22 PM
Old Trooper
May 17, 2011 06:00 PM
