key dont work in door
Old May 25, 2017 | 01:45 AM
happythree's Avatar
Default key dont work in door
last week i checked it and it was stuck,no unlock. i lubed it and it freed up. i added a good light weight lube oil. it was smooth.
today its stuck again??
wonder why?
Old May 25, 2017 | 08:04 AM
wonder why?
Interesting..... what lube oil did you use? Hope it was not WD-40?
Is the key original?
I have only used my door key in the door maybe 4 times in 10+ years, mine is probably dry, and the key worn from the ignition. Maybe they do not quite mate correctly anymore???
Old May 25, 2017 | 10:32 AM
happythree's Avatar
light weight penetrating/lube, good stuff. key is same as last time. ill try others today. i hate to pull it! even though i air chizeled an opening when i put it in a new door 2-3 yrs ago.
dont use wd40 much...
i forget if those pins are up or down for lube to get in. i had a jeep lock that was up. didnt lube till i pulled it?
Old May 25, 2017 | 03:13 PM
happythree's Avatar
Default key!
i pulled out my hidden key, from ace hdwe,6 yrs ago, not used. it works fine. u were right doc.
also forgot another ,,,in my wallet. old age...
Chance Koke
Jun 5, 2019 05:10 PM
chazyrae94
Jan 6, 2012 02:47 PM
mnext02
Sep 26, 2011 10:45 AM
amstaffbair
Jan 2, 2009 04:22 PM
importkiller
Oct 16, 2006 11:47 AM
