key dont work in door
last week i checked it and it was stuck,no unlock. i lubed it and it freed up. i added a good light weight lube oil. it was smooth.
today its stuck again?? wonder why? |
(Post 344778)
today its stuck again?? wonder why? Is the key original? I have only used my door key in the door maybe 4 times in 10+ years, mine is probably dry, and the key worn from the ignition. Maybe they do not quite mate correctly anymore??? |
(Post 344782)
Interesting..... what lube oil did you use? Hope it was not WD-40?
Is the key original? I have only used my door key in the door maybe 4 times in 10+ years, mine is probably dry, and the key worn from the ignition. Maybe they do not quite mate correctly anymore??? dont use wd40 much... i forget if those pins are up or down for lube to get in. i had a jeep lock that was up. didnt lube till i pulled it? |
key!
i pulled out my hidden key, from ace hdwe,6 yrs ago, not used. it works fine. u were right doc.
also forgot another ,,,in my wallet. old age... |
