Key does not come out unless brake pedal applied
Old Aug 17, 2016 | 09:20 AM
Jeff Bartnett's Avatar
Default Key does not come out unless brake pedal applied
So going to repost this since it's still an issue. 2003 H2. So the wires broke at the selonoid at the bottom of shifter causing key to be stuck. I replaced the connect and all wires were correctly matched/ connected. Selonoid on the shifter was replaced. Brake pedal sensor replaced and shift position sensors on tranny replaced. Still issues. If I go to turn off engine and remove key, key turns to engine off position but will not turn to the last position where u can remove key unless I put key in the run position and apply brake pedal and turn key to full off and then it removes. I'm baffled.
Old Aug 17, 2016 | 01:40 PM
HUMTECH's Avatar
sounds like you have a wire crossed at the connector on shifter
Old Aug 17, 2016 | 03:34 PM
Wish I did but they are connected correctly. Checked them three times. Also checked my solders job by testing voltage at the plug and that's all good.
Old Aug 17, 2016 | 06:03 PM
HUMTECH's Avatar
Key does not come out unless brake pedal applied-h2ignlock.gif heres the ign lock schematic
Old Aug 17, 2016 | 06:05 PM
HUMTECH's Avatar
Key does not come out unless brake pedal applied-h2shiftlock.gifheres the shift lock
Old Aug 17, 2016 | 07:21 PM
citiboy's Avatar
juicebox123
May 19, 2015 02:51 PM
4u33er
Jun 6, 2012 09:41 AM
AMG55
Apr 15, 2008 11:32 PM
HummerGuy
Feb 18, 2007 10:17 PM
melvynray
Dec 6, 2006 04:44 PM
