I changed the oil in the H3 today.....
Old Apr 2, 2008 | 11:19 PM
GOFASTER's Avatar
Default I changed the oil in the H3 today.....
This is the first oil change I've had to do since I bought the H3. What a PITA!!
GM engineer--"Hey...Lets put the drain plug right here above this crossbar!! That will make a huge mess and **** themoff royaly!! Then, lets put the oil filter right above another crossmember so when they pull it off oil will go from Hell to breakfast--Not to mention all over the front differential and onto the skid plates when they don't wipe it all out of this cool little spout doohicky!! Bwahahahahahaha!!"
Seriously--Do the body/frame guys not talk to the engine guys when they are putting a new vehicle together?? What a couple of f*#@ed up locations......
Old Apr 2, 2008 | 11:56 PM
Default RE: I changed the oil in the H3 today.....
They do it on purpose so the Japanese won't copy their design.
Old Apr 3, 2008 | 01:56 AM
moabxj01's Avatar
ORIGINAL: 3hummers
Ahahaha good thinkin on their part!
Old Apr 3, 2008 | 02:34 AM
That's why you go to the dealer!!
Old Apr 3, 2008 | 04:43 AM
blackstangs281's Avatar
GM had always been bad at this. They just care that they are easy to put together on the assembly line.
I think most people just take the skid plate off.
Old Apr 3, 2008 | 07:31 AM
GOFASTER's Avatar
ORIGINAL: blackstangs281
You have got to take both of the skid plates off to change the oil and filter, don't you? Imagine the mess if you didn't??
Old Apr 3, 2008 | 08:50 AM
Drop the skids, 6 13MM bolts, and a 13MM drain plug. The search feature will get you this: H3 Oil Change with Pictures
The tutorial says 1/2" skid plate bolts??? which would work sometimes (12.7MM), but it is all meteric? Another tip, park with the rear higher than the front, or jack the rear a tad before draining and you will clear the cross bar when draining every time.
On a level surface, the drain stream will not hit the cross bar on mine except at the very end when just a trickle.
25-30 minutes with hand tools, save 5 with a small air gun for the skids.
SEMO H3
18
Jan 20, 2009 08:30 PM
hummer07
Nov 18, 2008 10:46 AM
solarflare
23
Apr 3, 2008 04:33 PM
bomber01
Oct 7, 2007 05:01 AM
skeeet
May 19, 2006 11:04 AM
