Hummer h3x 3.7 2007 p0305 issue
Old Jul 19, 2016 | 01:23 PM
Alibou's Avatar
Default Hummer h3x 3.7 2007 p0305 issue
Hi i have p0305 issue: cylinder 5 mis
55 000 miles
H3 3.7
2007
P0305 at idle only
Fillup at unknown gas station.
Vin 88 128 101
Is it concerned by dreaded head issue ? ?
Vin is way above 68, its 88...
Old Jul 19, 2016 | 01:57 PM
55 000 miles
H3 3.7
2007
P0305 at idle only
Vin 88 128 101
I see you posted this same question in another thread. It need only be asked once.
What "dreaded head issue?", that recall was for 2006 H3s ONLY, hence your 2007 is not within the serial numbers for the previously manufactured L52 heads without the hardened valve seats.
What you mean is you got a CEL that showed up. You may have a bad coil on plug pack on #5 (rear most cylinder), or the wiring harness and/or connector are frayed, dirty, cracked..... etc. .... and/or you have water in the spark plug well of #5.
Easy check, pull off the intake, and inspect the wiring to, and coil pack connector at #5. If nothing looks like a problem, swap coil pack on #5 with any other cylinder's coil pack, look in the spark plug well for water at #5 when you remove the coil pack, and see if the CEL follows the former #5 coil pack. If you move #5 to #2, and start getting a P0302 instead of the 5, then you know that coil pack is going bad.
Old Jul 19, 2016 | 05:34 PM
Alibou's Avatar
Thank you
I am new to the forum.
I will do what you say.
So it has nothing to do with bad gas clogging injector or dirty maf + TB.
Fact is am in N.Africa and away from home, will wait to get back instead of getting stuck��
norinco3264
Feb 9, 2015 05:00 AM
norinco3264
20
Apr 25, 2014 05:51 PM
emac
Mar 11, 2012 07:24 PM
bsc819
May 20, 2011 02:59 PM
civilengineerh3
Feb 27, 2009 02:05 PM
