Hummer H3 Transmission Issue Need Help
Old Aug 8, 2015 | 05:59 PM
hummerblu33's Avatar
Post Hummer H3 Transmission Issue Need Help
anybody know what could be wrong with my 2006 h3? the transmission will sometimes not shift into 4rth until the car is shut of and restarted. It will also get stuck in a gear while hitting bumps on the backroads for instances like 3rd gear and wont shift until restart the vehicle. Car has 151k miles and tranny fluid was changed at 120k. I have checked transmission level and looked at fluid color. No burning smells and it doesn't shift hard or slip. When it wont shift into 4rth the gears bog out and does not want to down shift until I step on the gas more. I'm hoping this is a bad ground or something simple. I also want to mentioned I had issues with the key ignition around 130k miles if that has something to do with this issue.
Old Aug 10, 2015 | 08:32 AM
No need for repeated duplicate posts....
Might want to look at the other recent post on this topic also at the front of the board. https://www.hummerforums.com/forum/h...-50-mph-35666/
When they do not hold lockup, it most likely means rebuild time.
Old Aug 10, 2015 | 09:56 PM
eksreytek's Avatar
Hi Doc can you give me some approximate cost of a new trans and a rebuild one??
Old Aug 11, 2015 | 07:51 AM
That is all influenced by your local economy, on the East and West coasts, you'll pay more than in the heartland. In Detroit, a rebuild with standard OEM parts and a 90 day warranty is about $1750.
Whenever rebuild time rolls around, I usually go with heavy duty aftermarket parts in a few areas, which boosts the costs, but I think its worth it.
Old Aug 11, 2015 | 12:41 PM
rsc's Avatar
rsc
I think Hummerblu's problem is electrical not necessarily the transmission needing a rebuild. I remember seeing a chart of all the causes and symptoms a few months back, maybe I can find it again. Maybe the TCC solenoid going bad?
Old Aug 14, 2015 | 02:32 PM
Hello everyone sorry for the duplicate posts new to the site. I talked with my friend who is a GM certified mechanic and he ran me through a bunch of different causes to this problem. My issue ended up being my amp and subwoofers robbing my system. I also had a cold air intake that I put on the same time I hooked up my system. I removed both and it runs perfect again. If anyone adds in a system watch for issues like this cause it may be the problem. Also read that the cold air intake is bad for dusty roads and for my engine because I have the little 3.5l and it doesn't help getting dust in the engine. Didn't really notice a difference in performance either with cold air intake just stick with an aftermarket exhaust.
Old Aug 14, 2015 | 06:19 PM
happythree's Avatar
are you saying the amp,,,,caused the tranny problem???
id love to know how
Old Aug 14, 2015 | 07:01 PM
There are two bolts in fuse box and I tagged my amp cord onto the hot wire. Which in return was drawing power from my electrics. I did not put the amp directly to the battery. When I unhooked my system and drove on the same routes and tried to recreate the issue it wouldn't do it anymore. I hooked up the amp and subs back up the same way again today drove the same roads and it messed up my cars shifting. Did this to make sure it was the problem and not my transmission failing
linsys
Jul 24, 2014 08:55 AM
mdromanelli
Sep 30, 2012 08:50 AM
mdromanelli
Sep 22, 2012 08:16 AM
only_zeek
Jul 19, 2010 11:03 PM
