Hummer H2 crank but not start
Old Apr 22, 2019 | 11:57 AM
H2Miami's Avatar
Default Hummer H2 crank but not start
Suddenly the hummer wont want to start
The starter is good . The engine crank but wont start
Sometime seems like is going to start but it stalk
The passlock is not blinking. Steady while key goes on the off while trying to start then on again once key turn to on possition without engine running
I checked and switch the relays . No luck
Did a manual test on the gas pressure
With key on . Removed the cap . Press the valve and there was gas but the pressure was mimimal . Almost none ..the gas drip down without any pressure.
I will get a fuel gauge tester to be sure
But could be a faulty pump or is there an specific relay for the gas pump
Old Apr 22, 2019 | 03:04 PM
H2Miami's Avatar
tested with pressure gauge and reading was 0 psi ... I check a couple relays associated with the fuel system but Im not sure if missed something .
I would like to be 100% sure before pull the fuel tank down to replace the fuel pump
Anyone knows how to test if the pump is receiving power
Thank you
Old Apr 22, 2019 | 04:19 PM
Wisconsin03H2's Avatar
Default Did you use starter fluid
Hi.... Did you check that you are getting spark by having someone spin it over and spraying starter fluid into the intake? If you remove the Air Filter... have someone spin it over... and give it a 1-2 second squirt of starter fluid... and it kicks over or wants to come to life...then chances are compression and electrical are good. That may be a good way to point the finger to Fuel pressure.
Colby
Old Apr 22, 2019 | 04:50 PM
H2Miami's Avatar
Hi Colby .. I was going to do that if the preasure were good . But after testing and reading 0 psi in the fuel . I dont think is necessary.
For sure the problem is the pump went bad or not receiving power
Which Im not sure how to test
I guess removing the tank and replacing the pump will be the best shot
Old Apr 23, 2019 | 05:54 AM
oceanbrave's Avatar
Old Apr 23, 2019 | 08:07 AM
clsimmon's Avatar
It's an easy check. Quick test; stand outside your truck and turn the ignition to On and listen for a 2 second wine of the pump under the truck near driver side rear seat area. If you hear nothing, you do know there is an issue somewhere with the fuel pump.
Next, reach on top of the fuel pump and pull the fuel pump harness. With your multi-meter connected, have someone do the same test by key in the ignition and rotated to the On position. You should see 12v for about 2 seconds. If not, you know you have a circuit issue. If so, you know you have a fuel pump issue.
Old Apr 23, 2019 | 09:10 PM
H2Miami's Avatar
Thank you . Very good info
I know the pump is not working . No preassure. The relay click when switch is on
However like you said it would be a good idea to check the pump connections . I will give a check before taking the tank down
Kourtney Wagner
Feb 18, 2016 07:56 AM
kevinocon86
Feb 13, 2015 12:44 AM
Captchee
Dec 21, 2013 08:39 PM
djbit
Dec 2, 2011 10:14 PM
logicbyondreason
Mar 24, 2011 10:55 PM
