Hummer H2 2005
Old Jun 22, 2019 | 06:42 PM
DNegronV's Avatar
Question Hummer H2 2005
Good afternoon I have a problem
I Install new oil pump new time chain and I don't have oil pressure inside the engine
Old Jun 22, 2019 | 11:16 PM
oil pressure is created by the crankshaft bearings. if they are worn badly then it can be an issue.but start with the simple things like checking the pickup tube O ring and the oil pressure relief spring.
you can start the video at 2.24 if you find his rambling too loud.
Old Jun 22, 2019 | 11:55 PM
legerwn's Avatar
did you prime the engine and pump?
Old Jun 23, 2019 | 04:53 PM
DNegronV's Avatar
oil pressure is created by the crankshaft bearings. if they are worn badly then it can be an issue.but start with the simple things like checking the pickup tube O ring and the oil pressure relief spring. https://youtu.be/DoCQEdXYTGQ?t=142 you can start the video at 2.24 if you find his rambling too loud.
@bronxteck I did everything the same way the guy in the video before I take the oil pump out
Old Jun 23, 2019 | 04:55 PM
DNegronV's Avatar
@legerwn how do I prime the engine
Old Jun 23, 2019 | 09:18 PM
usually you disable the fuel pump by pulling the relay or fuse and then you crank the motor till you get an oil pressure reading.
Old Jun 23, 2019 | 09:46 PM
legerwn's Avatar
You can buy a primer or make one like I did. A pump up sprayer filled with engine oil and connected to the oil galley at the drivers side front of engine. Pull the plug and prime the pump and engine, the pump is dry and usually will not prime on it's own. You can find fittings to screw the sprayer hose to the block or just use a air nozzle with the rubber tip on the sprayer hose and hold it in the galley plug hole and fill it with oil. The hole is at the pump discharge so the pump will fill quicky.
Neal
Old Jun 23, 2019 | 09:47 PM
legerwn's Avatar
Melling has some good videos on their web site that explains the process.
Old Jun 24, 2019 | 01:47 PM
DNegronV's Avatar
Thanks for the suggestions
Old Jun 24, 2019 | 01:51 PM
DNegronV's Avatar
I already prime the oil pump and I do not know anything . I think I have to change the main bearing
Joeybiff
Jan 10, 2019 03:34 PM
H2Miami
Dec 3, 2018 05:20 PM
ferraribuyer
Mar 27, 2017 09:04 AM
DanH3
Jul 11, 2014 08:15 AM
tommyb123
Jan 11, 2012 03:18 PM
