Hey Doc have ? About my H3 2007
Old Jun 24, 2019 | 11:25 AM
Twtoys's Avatar
Default Hey Doc have ? About my H3 2007
Yes my H3 is loosing a small amount of antifreeze out of the reservoir after engine shuts off about 5min I found where it is coming out of a very small tube under the H3 last old like it’s made be a overflow are something?? What I’m I seeing here could it be water pump going bad Thanks in Advance
Old Jun 24, 2019 | 12:49 PM
amrg's Avatar
Depending on what your climate is it could be normal or pointing to an issue.
When the truck is shutoff after reaching full operating temp, heat soak from the engine block will get coolant temps higher and the radiator cap will eventually let it vent into the overflow tank. If too much coolant is vented into the tank it will fill it and spill out into the engine bay through that hose. Hotter weather will lead to more engine heat so more coolant will overflow. What you could do is
1. When the truck is cold, check the coolant isnt above the cold level mark in the overflow tank. If more, then you may have over filled it and it will keep overflowing until you reach the proper level (keep in mind again that summer weather will tax the coolant more than winter so that cold level may vary abit)
2. If the level is too low, check the pressure cap, it may be releasing coolant earlier than it should and overfilling the tank.
Old Jun 25, 2019 | 08:48 AM
Clean it off at the spray wash. Drive it to heat it up and dry off the water and engine cleaner you used. Look for exactly where the coolant is coming from.
daniiel777
Oct 6, 2019 09:55 PM
hkench
Mar 19, 2019 01:26 AM
abhijeetgadhave
Sep 11, 2018 07:47 AM
jayhawk714
Jul 17, 2016 09:36 AM
Herm
Jan 24, 2008 07:04 AM
