Hummer H1 frame chassis
Old Nov 17, 2017 | 01:05 PM
gbales87's Avatar
Default Hummer H1 frame chassis
~~Asking $7800 OBO~~
Humvee / H1 roiling chassis + parts
This chassis has been completely disassembled professionally blasted and painstakingly recoated with Cerakote C-7300. One of the most durable coatings on the market.
Every nut bolt and washer have been individually striped and coated.
This frame is ready to go – perfect for a Humvee / H1 body or rock climber. If you are looking for a 4 wheel steering application this is an exhalant candidate!
Portal Hubs Completely rebuilt with all new bearings, races and seals, + micro slick gears
Joints / Bushings
All bushings on both upper and lower A-arms have been pressed out and replaced with new NOS bushings.
All Ball joints were replaced with up-armor ball joints to insure max strength
2 New Steering tie-rod ends are included as well.
Shocks / springs / Air Ride
4 new Shocks are included
4 coil springs are included but not yet coated
Parts to fabricate air ride are available at request – negotiation
Portal Hubs / Differentials
All 4 portal HUBs have been completely striped blasted coated and rebuilt. Each Hub has been completely been disassembled and new Timken bearings and races were pressed into HUB assemblies. Each Hub has new seals and gaskets and all of the gears have been coated with Cerakote micro slick coatings.
2 Differentials are included and have been blasted and coated as well. Each differential was completely checked out and verified to be within tolerance. Differential covers have been coated with Cerakot burnt bronze and Armor Black. The original bolts have been removed and replaced with Allen head Stainless Steel hardware.
Tires / under armor / Rear Wench Plate
The tires are in the 30% tread life and are the Baja T/A Run-flats
Rims are blasted but uncoated.
A complete and new Under Armor kit is included as well – complete under carriage protection.
A new Rear Wench mount kit is included as well
A new rear bumper is included. – blasted finish uncoated
Additional Parts / Components
2 Rear mount AC condenser & fan kits – includes inner wheal well. - New
1 Complete Under armor Underbody protection - New
1 Windshield Frame – New
1 Rear Brake caliper – New
1 Fuel Tank & mount + sending unit – New
1 Rear bumper – new blasted uncoated
2 HD tie rod ends - New
2 Soft doors – new
4 air ride suspension bags + connecters and Hose – Negotiated
Shipping
Buyer is responsible for local pickup or arrange for their own delivery.
Fork lift assistance is available
The dimensions are approximately 7’6” wide X 15’ long
Approximate weight is 2900lbs chasses
Additional parts 1000lbs
Additional pictures upon request --- Located in Wentzville, MO
Call Jeremy Dean for this at 636-541-9947 he's the one that did all the work on this, I am just trying to help him sell it by adding it to a few places online.
I have added a ZIP compressed file with all the pics for everybody to view, there's just too many to post individually.
Attached Thumbnails Hummer H1 frame chassis-img_2828.jpg   Hummer H1 frame chassis-img_2823.jpg
File Type: zip
Old Nov 17, 2017 | 01:06 PM
gbales87's Avatar
What is for sale is the Hummer frame and all the parts that we took pictures of that are in the ZIP file***
Old Feb 12, 2023 | 09:08 AM
AjK-VA's Avatar
Joints / Bushings
2 Soft doors – new
Shipping
Hello, I will assume that this chassis is long gone. I'm mostly responding to ask if you have a direction you can point me in regarding other rolling chassis' you may know of, or companies that do this type of work in the US. I'm in Virginia. My ride is a 2002 H1 soft top.
Old Apr 13, 2024 | 03:21 AM
Maverick2322's Avatar
Default Rolling chassis
Hello ,
Do you still have the Humvee rolling chassis
Old Apr 13, 2024 | 06:38 PM
i doubt it the poster was last on 7 years ago and only posted here 2 times.
  • Last Activity: 11-17-2017 01:07 PM
Old Apr 15, 2024 | 08:08 PM
Originally Posted by Maverick2322
Hello ,
Seriously? READ: Old Threads/'Necro-Bumping'
OceansEnd
Oct 11, 2020 09:51 AM
ben1272
Aug 29, 2020 01:45 PM
jsbihn
Mar 11, 2015 09:13 PM
Dgl
Mar 2, 2014 07:06 AM
davewood767
Mar 25, 2009 03:13 AM
