Hub ?
Old Sep 18, 2013 | 11:38 PM
H2Miami's Avatar
Default Hub ?
Im going to replace the Hubs due to the Popping sound I talked before , now there is also a grinding sound when in reverse with the wheels turned to the right ,,,
Which is the best Hub I can buy .. I rather to stay away from the OEM cause the seems to fail offer
Old Sep 19, 2013 | 05:47 AM
Chad_Arild's Avatar
Default Buy USA made..
I buy Wagner parts, ( I have not had to replace hubs my H2 or H3...YET, but I did on our GMC 2500HD) just don't go cheap...you now the saying,
"You get what you Pay for,"
Old Sep 19, 2013 | 11:11 AM
Kirkhayes37's Avatar
I heard Timken is OK. Got one at RockAuto for about $168 shipped. Some say the popping can be the CV shafts.... they are easy to change out too. Just not sure how to tell which is making the noise...the CV or the Hub..
I actually rotated my tires and 99% of my noise went away....Can't tell you why that seemed to work!!!???
Old Sep 19, 2013 | 12:35 PM
H2CANEPADESIGN's Avatar
Its a tough thing to diagnose over the net. best way to check is to get all four of your tires up off the ground then spin the wheels. put your hand on the upper control arm while the tire is spinning and feel for any roughness, also shake the tire up and down and see if there is any play in the bearing at all. if there is its time to replace. there should be absolutely no play in the bearing. a lot of things can cause a popping or grinding feeling/sound in the vehicle. c.v. joints, tire cupping, control arm bushings, even your rock shield on the bottom sometimes can flex while turning and cause a popping noise. Timken is a decent brand although personally on parts like that I prefer O.E.M. unless there is a clear upgrade available. I wish I could say that I know there is on the hubs but Ive used aftermarket ones on customers vehicles and no such luck. I have never tried the Kryptonite hubs though.
Old Sep 19, 2013 | 10:49 PM
H2Miami's Avatar
I rotate the tires too and the noise went away Or at least I thought so for a day
The problem is actually while driving around 45-60 mph , no when turning .
Also a few day ago I heard a chirp when in reverse with the wheels turn to the passenger
Im going to test like H2cane said to try to identified the problem before buying parts ... I dont know what else to see .
I did check the mounts , the exhaust , the shield , balance and rotate tires but no luck
The bump can be felt through the floor . It is intermittent
Only I can do is keep guessing
dscaberboy
Jan 27, 2008 06:27 PM
gpshemi
Dec 7, 2007 06:56 AM
HummerGuy
Jan 29, 2007 06:01 AM
crank
38
Nov 26, 2006 06:04 AM
crank
Oct 13, 2006 06:00 AM
