How long to pressurize fuel line between uses 08 H2?
Old Jun 26, 2017 | 02:53 PM
gopantherpride's Avatar
Originally Posted by legerwn
Key in run position and engine off prior to start up the fuel pressure is 60 psi
crank engine and the fuel pressure stays around 59 to 60 psi then drops to 44 psi and holds there while driving.
Neal
The statement of 49 psi as tested by the auto shop was key in run position but engine off. Sounds as though my pump is not only weak but that the check valve is bad since the fuel lines need to be completely repressurized after 4-5 hours of down time.
Old Jun 26, 2017 | 03:02 PM
What brand of fuel pump are you going to buy? The fuel pump is one item that I would only buy the OEM part. I have not had good luck with part store fuel pumps for very long.
Definitely ACdelco. So far the best price I can find shipped is $240.78 with fuel level sensor for the MU1656 from RockAuto.
Old Jun 30, 2017 | 10:37 PM
yrkdmaxh2's Avatar
Pete responded to a question about a 2003 H2 and you asked about a 2008 H2, these are completely different engines.
My fuel pressure is 44 psi while driving and the truck runs fine, I'll look up the fuel pressure specs for the 08 6.2l engines.
If I remember correctly the 08 has a fuel pump control module which I think is a variable speed pump (PWM). I could be wrong, I'll look it up and see.
I'll run out and do a quick fuel pressure test,
Neal
Neal is spot on, the 08, and 09's have FPCM that are known to fail.
Do you have any CEL's, or an intermittent service 4wd system?
Old Jul 1, 2017 | 12:08 AM
Nope. Just gas smell at start up, slightly rough idle, weak psi, fuel lines lose all pressurization after 4-5 hours, etc; etc...
Old Jul 1, 2017 | 10:39 AM
legerwn's Avatar
May be an injector leaking down into the intake, this would explain the gas smell at startup and the loss of pressure.
If it was the pump you would not get the rich smell at startup as the gas would just de-pressure to the tank.
Neal
Old Jul 2, 2017 | 11:59 PM
Neal
A leaking injector was my original thought which is why I brought my truck in for the leak down test. They wanted $$$$ to replace my injectors without knowing if that was my actual problem.
Old Jul 3, 2017 | 12:02 AM
I don't have any CEL's or service alerts but I'm wondering if I should check with GM to see if there are any standing recalls on my truck. I found one for the FPCM that was released in January 2015.
https://www-odi.nhtsa.dot.gov/acms/c...4V614-0055.pdf
Old Jul 3, 2017 | 09:38 PM
legerwn's Avatar
If you can find someone with the correct scan tool they can perform an injector balance test. If there is a failing injector it may show up then.
You may even be able to let it sit for a few hours then pull the plugs and see if any are wet with fuel, its a long shot but if you have the tools to pull plugs you can do it yourself.
Injectors fail, get dirty, leak, etc....
If it cannot be found with the above tests then they may have to be pulled and checked or replaced.
Neal
garnaout
Feb 3, 2012 01:25 AM
Geraldo
Mar 26, 2011 01:16 PM
RealJeep
Jun 17, 2008 10:16 PM
dscaberboy
Oct 8, 2007 04:52 PM
HummerGuy
Aug 8, 2006 07:54 PM
