How do you remove reaer tire carrier?
I have an 03 H2 and want to remove the rear tire carrier to clean and lubricate. I thought that you could remove the spare and simply pull it out of it's bumper attachment, but it is really in there, I even tried to use a bottle jack to push it out from below but it lifted the whole back end instead. Any ideas?
From what I was told its a pressed fit, your going to have to remove the grease fitting and put some PB Blaster there and around the swing mount to free it up.......
I use mine daily and grease it every oil change..........its like the old saying........Use it or Loose it.......
Good Luck..............Rick
it is a press fit on the '03 mount. unless it's rusted in, it will simply lift out, with some persuasion. might want to make sure you've got the pin out on the driver's side before trying to lift it.
i'd use synthetic grease, seems to last longer and keep it moving more smoothly than the dino stuff. that things totin' a lot of weight, you want something that will last longer than silicone. i use the same grease as i use on the ball joints and steering components.
Just so long as it's clear eh? I have some lithium grease that i sprayed on my garage door to stop the squeaking 5 years ago and its still holding. LOL
Problem is its a nasty yellow that is a pain to clean up. :P
ORIGINAL: shortbus
Andreas_Sweden
Mar 19, 2025 12:16 PM
07H3driver
Nov 24, 2014 01:30 PM
RJ3607
Oct 20, 2014 03:36 PM
SShockwave
Jun 28, 2011 07:39 AM
noavgcobra
May 10, 2010 11:34 AM
