Wind noise
Old Apr 26, 2007 | 09:40 AM
xchief's Avatar
Default Wind noise
Just installed roof rails on my H3 , and found the wind noise annoying. I moved the front rail back a bit and that seems to have helped some.
Was wondering if a sunroof deflector would also help , has anyone done this or what have you found to help .
Old Apr 26, 2007 | 10:46 AM
LawWyfe's Avatar
Default RE: Wind noise
Odd...I assume of course that you have them installed correctly...I have never experienced wind noise problemswith mine.
Old Apr 26, 2007 | 10:53 AM
Dennis's Avatar
I got some noise with mine too..I have front one set right past the point in the track that you install them. the leading edge of the mount is lined up with the seam in the track where the filler plate endsand the back one is about 10" from the rear travel limit..I was thinking about moving the front one back a little more..
Old Apr 26, 2007 | 11:33 AM
xchief's Avatar
Hmmmm , I think they are on right the travel disc is in the trac but I will check. Also I now wonder if the rear one is too far back and that is what I am realy hearing , I am going to try moving the back one up more by the rear piller (sort of how your avitar pic shows ). Will let you know how that works.
Nice to find your forum , and thanks for any advice .
Old Apr 26, 2007 | 11:44 AM
LawWyfe's Avatar
Welcome to the forum chief! Great buncha folks here. I have learned much and found great places to purchase Hummer items, as well as had many chuckles here! As for the placement of my rails, the sun roof pretty much dictates the placement of the front rails (as well as the slots) and I wanted them to look fairly proportionate in placement so I moved the back one up a bit. Chances of me actually using them are pretty slim and I got them merely for looks sake. To me the H3 just looks as if it is missing something without them.
Old Apr 26, 2007 | 02:30 PM
NJTEX's Avatar
Moving the racks back behind the front doors when you're not using them to carry something will help even more. The further they are away from your ears, the quieter they'll sound. Try moving them around and see for yourself.
I really don't like sunroofdeflectors because theyblock the sunroof opening.The H3 is the first vehicle that I've owned that I can actually notice sky above me when it's opened so I don't really want toblock the view.
Old Apr 26, 2007 | 02:33 PM
Dennis's Avatar
As you can see my rear one is a little further back than Sarah's..I think I'll move it forward some and see if that makes a difference...
Old Apr 27, 2007 | 12:32 AM
Dennis's Avatar
Up-Date
I moved the rear ones up to where the front edge of the mount lines up with the seam in the plastic trim right above the trailing edge of the rear door...
I'm not a 100% sure, but I think that helped a lot...I could only get up to 68 MPH, because I wason school zone and couldn't open er up.[:@]
Old Apr 27, 2007 | 11:26 AM
xchief's Avatar
Yep, did the same as you Dennis with the same good results. At the least it is now tollerable. Hard to believe just a few inches made that type of differance, but then again a few inches can make all the differance in the world ...just ask my wife....haha
Old Apr 27, 2007 | 02:36 PM
ChevyHighPerformance's Avatar
Dennis,
My roof mounts (triangular hoops) are mounted outside of my roof rails. Did you change yours?
