How do I permanently stop the AutoHeadlights from coming on at startup?
Old Apr 6, 2019 | 02:45 PM
  #31
Originally Posted by ski.dive
YEP!!! I'm letting the truck do his thing!!!
How do you find the gender of a truck?
Old Apr 14, 2019 | 04:40 AM
  #32
h3/z28/t.a.'s Avatar
Originally Posted by wfturner
Actually you can not defeat it through the switch.
The ambient light sensor operates between two voltages. If the ambient light drops too much, the voltage changes and the BCM turns the headlights ON. Conversely, if the ambient light is high, again the voltage changes and turns (the already on headlights) OFF.
I have done my homework on this feature.
The only way you could control the headlights by disassembly of the headlight switch would be to have the lights never come on, ever.
Bottom line is just leave this feature alone and let the truck do its thing. Are you reading this Ski.dive ??
There is a way then,
the sensor is located on the dash, must be pretty easy to disconnect. If the lights still come on, then we need to fin out what voltage it gives in daylight.
If the lights dont come onn if the sensor is diconnected, then you can even add a switch to disable automatic lights when you need to.
Then the daytime running lights might need disabling , so that all lights stay off.
To go full stealth mode lol, PM for tips hahha
Old Apr 14, 2019 | 05:18 PM
  #33
wfturner's Avatar
I'm afraid that your info and assumptions are incorrect.
The sensor controls the voltage and the BCM software program controls the lights (on/off).
If it were a simple turn on turn off by the sensor the lights would come on and off too rapidly.
It sounds like you have an idea to drive at night with no headlights, which is just
a ridiculous and dangerous idea
One further bit of proof of the headlights complicated operation is the wiring to the headlights.
There are only three wires to the headlight bulb 12V, high beam and low beam.
The DRL function is again controlled through the BCM, not through a separate wire
Old Apr 14, 2019 | 06:34 PM
  #34
The LDR is a resistor. You can't just turn it on/off, however you can bypass the LDR with a standard resistor, that will not change the values ever, day/night.
Old Apr 14, 2019 | 07:01 PM
  #35
Just pull the LDR, get your multi-meter set to ohms, test the LDR, to get the value in the bright daylight. Replace the LDR with a standard resistor in ohms with your results.
Old Apr 17, 2019 | 04:47 PM
  #36
bosscar's Avatar
I don't know why everyone is being a jerk about the guys question. He probably just wants to shut off the daytime running lights.
I can't stand cars running headlights during the day either. You can just pull out one of the fuses under the hood and it shuts the function off. Easy.
Found another thread about this a long time ago and it works. Let me see if I can find out which fuse it is. 4 years ago is too far back to remember.
Old Apr 18, 2019 | 06:59 AM
  #37
wfturner's Avatar
What is the "LDR" ?
Old Apr 18, 2019 | 07:24 AM
  #38
Broken Halo's Avatar
Dyslexic for Daytime Running Lights
Old Apr 18, 2019 | 08:35 AM
  #39
wfturner's Avatar
I figured it might be that . . .
ski.dive-
And . . . the DRL function is not controlled by the ambient light sensor on the dash.
The DRL is solely controlled by the BCM. Pulling fuse #39 defeats just the DRL function, which is old news to most of us.
And installing a permanent resistor in place of the ambient light sensor could cause problems with the BCM.
Isn't it easier to just turn the headlight switch to the left and release after you start driving ?
Old Apr 18, 2019 | 12:34 PM
  #40
What is the "LDR" ?
(L)ight-(D)ependent (R)esistor
