Help with Leak.
Old Jul 16, 2016 | 02:47 PM
groomsxxx's Avatar
when you added your cooler, did you happen to bypass the stock unit?
Old Jul 16, 2016 | 02:53 PM
WR3NCHE4D's Avatar
I still use the radiator cooler. Against common practices I ran through the cooler first and then to the radiator. Either way it is connected will help.
Old Jul 16, 2016 | 02:58 PM
groomsxxx's Avatar
i gotcha. yeah I am going to bypass the radiator cooler. I just wanted to confirm that I could basically plug off the radiator trans cooler by using this
6 An Male Flare Plug Fitting Aluminum Blue | eBay
Old Jul 16, 2016 | 09:46 PM
WR3NCHE4D's Avatar
If you want to block off the transmission cooler at the rad you are going about it the wrong way. There is no nuts on the lines. The lines snap into the radiator and are held in by a wire clip. Some after market companies produce repair lines that will go in place of the factory lines. From there you can cap off the lines or connect them with a rubber hose.
Old Jul 17, 2016 | 12:06 AM
groomsxxx's Avatar
oh ok. thanks so much for that info. What would happen if I didnt block it off at all though?
Old Jul 17, 2016 | 12:25 AM
register1987's Avatar
Parts of that information is correct. Yes the lines are held in by a clip but they snap into an adaptor that screws into the rad. You can unscrew the adaptor and replace it with a cap. From my Googleing it seems that user groomsxxx is correct and it is a 6an plug you would need
norinco3264
Oct 31, 2013 10:29 AM
CarlosC
Oct 28, 2013 03:19 PM
ukpaul
Nov 19, 2011 07:26 AM
DH3
Jun 14, 2010 09:06 AM
hummerray
Feb 15, 2009 05:51 AM
