Heated seat problems
Old Feb 11, 2015 | 11:51 PM
theboss's Avatar
Default Heated seat problems
Hey guys im having issues with my seated seat i press the button and they turn off right away.. I searched on the net someone said fuse relat but im not sure
Old Feb 12, 2015 | 10:53 AM
collega's Avatar
Check your fuse in fuse box, in engine compartment.
Old Feb 13, 2015 | 07:24 AM
h2offroad's Avatar
I have a leak near my driver door, and water will sometimes get behind the seat hearer and it'll act crazy. It'll shut on and off and go thru all the settings. When it dries it's 100% normal
Old Feb 13, 2015 | 08:15 AM
H29R's Avatar
I'm hearing the seats need a flash update eventually. I have it quoted from a local GM dealer for 100 bucks.
Old Feb 13, 2015 | 11:44 AM
collega's Avatar
I never heard about it before. It's good to know. Hopefully I will not need it. But why and how is heated seats system could be updated electronically? Do dealership try to do it through car computer?
Old Feb 20, 2015 | 10:02 PM
Terds's Avatar
Other GM's vehicles Escalade's for sure have a problem with the connector under the passenger seat that controls the heated seats. It does not make good connection within the connector and melts the plastic and heats the metal causing contact problems. If this is your problem and it is not too bad you can unplug it squeeze the female contact down a little tighter and that could be enough to fix it. If the connector is melted bad enough you may have to replace both side or just solder wires together with no connector. If you find the connector and it is melted it should be obvious when you look at either side of the connector after unplugging it. It may be melted badly enough it won't unplug. I don't have any pics.
gixxer007
Sep 2, 2009 03:23 PM
Keithmo
Apr 8, 2009 10:00 PM
h3andme
Feb 26, 2008 08:18 AM
flyjets
Jun 12, 2007 12:07 AM
07HummerH3
Jan 29, 2007 06:20 AM
