Headlights
Old Dec 16, 2017 | 08:26 AM
calif phil's Avatar
Good find on the video. It's good to know that there is an actual 2a fuse.
I won't comment on the repair in the video. LOL
Old Dec 16, 2017 | 09:47 AM
I had not watched it till just now.... In his defense he does have a soldering iron and solder shown and states that he is about to solder and button it up at the end so I'm assuming the hanging twisted on method was just for testing.
Me personally, if I were needing to replace that fuse I'd have some heat shrink slid up each wire side, solder new longer wires and would extend the wires for the fuse holder down to the junction block just above the left dead pedal area and install it under that junction block cover and put a label on the wire/fuse holder indicating what it is for to make it simple to change in the future if ever needed again.
Old Dec 16, 2017 | 04:22 PM
Rhodesia's Avatar
Default inline fuse
Originally Posted by MixManSC
Will be a while before I can find time to look at the service document stuff but I can tell you this much. Everything electrical on the front of the steering wheel goes through the clockspring. The clockspring is a long thin flat flexible electrical circuit with a number of wires that connect at each end. That is coiled up in a casing and is what lets the electrical things like the airbag, horn, steering wheel buttons (and their backlights) work without having actual wires getting constantly twisted up and broken from turning the steering wheel.
The clockspring can indeed go partially bad but that is uncommon. Generally the only time the clockspring gets damaged is if the steering shaft is disconnected and then the steering wheel is rotated 360 degrees a few times - that will destroy the clockspring - but then no function on the wheel would work if that were to happen.
Also the steering wheel control buttons are the same ones used on all GM trucks. Even the steering wheels and airbags are interchangeable. I have an Escalade wood/leather steering wheel in my H2 and its the buttons that came on the Escalade wheel from the junkyard. I did use the Hummer airbag on it though as I was not really wanting a big caddy logo. lol
I'm not aware of any sort of inline 2a fuse as mentioned but that does not mean there is not one. However you can google for GM truck steering wheel control buttons not lighting up or not working and find a TON more results for the trucks since those are far more common than the Hummers. As long as its a model from the same year range with the same style steering wheel the buttons and how they work are pretty much identical.
Edit to add - a quick 30 second search found these - so yes apparently there is a fuse inline close to the BCM under the steering column... I think the last one is a video of someone replacing that fuse. I just googled "gm truck steering wheel buttons light 2a fuse"
Fuse for steering wheel control lights - Chevy and GMC Duramax Diesel Forum
Steering Wheel Control Light Fuse (?) - Diesel Place : Chevrolet and GMC Diesel Truck Forums
https://www.youtube.com/watch?v=0eqZ..._channel=NickF
well I looked under my dash took off everything to see if I had an inline fuse and the Hummers don't have inline fuse for the steering wheel controls lights, it is all tide into the clockspring, so not I have to buy a new clockspring just so the light will work on the control buttons. boy that was a waste of time taking all that apart. The GM Mech told me he did not think it had one and did not see anything in his mech books for the steering wheel harness for an inline fuse 2amp. So now I have to buy a $400 dollar clockspring you would think the Hummers would make things easier to fix but it one bulb goes out you have to replace the whole device.
Old Dec 16, 2017 | 06:24 PM
No fuse wrapped up in a wire like shown in that video? It will be pretty small. I think you just did not find it. This is from the actual GM TIS Service system. Upper right on this diagram shows the 2A fuse and this is specifically for a Hummer H2. Brown /white wire that goes to pin C2 on the instrument panel relay block.
Just would hate for you to spend a ton on the clock spring and find out that it was not needed. Also - the clock spring for the same years GM trucks and full size SUV's is identical and as long as it is for a model with the same style steering wheel with steering wheel controls it will work. Truly Hummer specific parts do cost more - things like the driver door window switch module (DDM) is Hummer specific. Looks identical to other GM truck ones but certain things will not work right if its not the right one. Generic wiring only things like the clock spring are the same.
Old Dec 16, 2017 | 10:56 PM
Rhodesia's Avatar
Default inline fuse
Ok I will give it another look tomorrow, but I sure did not see any what looked like a fuse link. I will let you know because this getting to be a quagmire of a job. again thank you
Old Dec 17, 2017 | 08:54 AM
It will just be a couple inches or so long part on the wire where it has a black covered thicker spot.
This thread (seems you can click the attachments and view the images without an account) shows a few pics of it on a GM truck.
Old Dec 17, 2017 | 12:45 PM
Rhodesia's Avatar
Default inline fuse
So far the whole steering wheel harness is wrapped in blacked factory tape looks like I have to peel most of it away just to fine the inline fuse. It also look like the end the harness attaches to a black box labeled borg warner with 3 clips one labeled BLACK the second labeled GREEN and the other labeled BLACK I did see what looked to appear to be a brown and white wire this black box is located under your left knee if sitting in the drivers side, the only other black box is mounted to the firewall on the left side of the brake pedal .
Old Jan 2, 2018 | 01:22 PM
Rhodesia's Avatar
Well I could not find the wire or the fuse, the GM dealer Mech said hummesr DON'T have this 2 amp fuse that operate the light in the steering control buttons so I spent $204 for him to tell me that answer because that's what the dealership charge per hour if it has to deal with Elec issues. I showed him the wiring chart and he said its not from a hummer. I have seen people fix the issue on you tube as pictured above but again I sure can't find it. To top that GM no loner makes the harness anymore can't take a chance getting one from a salvage yard so I'm at a loss here unless someone out their can at least give me another ideal. The buttons functions work fine with the steering wheel and the radio and onstar, but they just don't light up. I also found out they no longer make the airbag for the H2 hummers, too funny might as well put a balloon in there.
Old Jan 2, 2018 | 06:24 PM
The airbags are easy to find used...
That guy at the dealership is an idiot and flat out lied to you. That PDF I uploaded is correct and for a 2005 Hummer H2.
Here is another look at it. This version is more specific (the other shows a lot more of a general look at wiring system for locating things) for the dimming systems related to the steering wheel controls and is directly from the exact system that the GM dealerships use for technical repairs and troubleshooting and is specifically for a 2005 Hummer H2. So according to the dealership guy the document is not for a Hummer and on this one as well, then GM must be lying is this is an actual GM document and even on this one you can clearly see the 2A fuse. Just like GM does on every single other GM truck from 2003 through 2007. Except yours I guess according to that dealer you went to...
That stealership needs to go back and check again at no cost to you. Tell them to pull up the GM TIS System and search by Document Number for #1407197 then look it up by vehicle year/make model and look under Body>Lighting Systems>Interior Lights Dimming Schematics>Fig 4 and see what he finds... this document.
Its pretty sad when some guy on the internet is better at using the GM Technical Information System than some supposed tech at a dealership....
I will not have time during the week but just to see for myself, I'm going to try and make time to look on my 2003 and see if it has that. According the the ESI the 2003 H2 (Document #831493) has the same fuse in the same place....
This thread on here also shows it... https://www.hummerforums.com/forum/h...ighting-26868/
I guess it could be what that guy had though. On his a different issue but similar and his was a wire on some connector had come out of the connector itself. Also tricky to locate. That being said I'd still push the dealer for lying (that fuse is very clearly in the genuine GM documents for a Hummer H2 and its also on EVERY GM truck that uses that exact same style steering wheel with steering wheel controls) and try to make them check again at no cost.
I just feel bad that they charged you for that and then denied that the diagram I uploaded was for an H2. It most certainly is.
File Type: pdf
Old Jan 2, 2018 | 09:49 PM
Rhodesia's Avatar
Default 2amp fuse
Thank you very much for your help really, this is a big dealership where i live and when they do get any type of used H2 Hummers in they sell fast so they don't stay on there lot long so you would think they would know how to fix them, they are always asking if I want to sell mine when I drive up in it. I always say no because I have two knee replacements from combat injury's in Iraq so this type of vehicle makes it easy for me to get in and get out because of the leg room I'm just trying to fix something simple that someone else is making it harder than it looks, I tried looking for that wire brown and white strip did not see it in all that mess, on the floorboard next to the break pedal there is a gray box with a black cover it appears that the wireharness leads up to the steering wheel and I also have another box which is black in color labeled Borg Warner also near the other box on the floorboard and it also has wire harness leading to the steering wheel so it makes it confusing, I have see the you tube video they make it look easy to do yourself if you can find the wire that is. Again thank you.
Ta Jay
Sep 23, 2022 01:35 PM
OAHU_H3
Jan 7, 2007 09:21 AM
importkiller
36
Dec 22, 2006 05:58 AM
suzyq633
Dec 8, 2006 07:17 AM
importkiller
May 23, 2006 10:28 AM
