H3 stuck in 4high
Old Feb 8, 2015 | 07:57 AM
marty22222's Avatar
Default H3 stuck in 4high
I have a 2006 H3 and it is stuck in 4high. Im thinking shifter fork broken. My question is can I pull the front drive shaft out and run it till i can find a mec. in va beach area that can fix it. Thanks
Old Feb 8, 2015 | 10:47 AM
RKSmith163's Avatar
4 High is what you are suppose to be in for normal driving. That is the default. Will it go into 4 High Lock or 4 Low? Please consult your Owner's Manual.
Old Feb 9, 2015 | 06:45 AM
marty22222's Avatar
Default H3 stuck in 4 high lock
Im sorry I ment its stuck in 4 high lock
Old Feb 9, 2015 | 07:38 AM
kramcard6's Avatar
my 07 h3x done that once, try pressing four high while backing up, i called onstar and they transferred me to GM support and that's what got mine out and it never did it again. But i've really never had a use for any of the other sittings, 4 High goes anywhere i want it too
Old Feb 9, 2015 | 10:37 AM
RKSmith163's Avatar
Exercise your buttons a few dozen times and try cleaning between them. There are a few that have had them stick. Even if it is the shift fork it is less expensive to fix than a lot of things. Good Luck.
Old Feb 10, 2015 | 09:48 AM
While it could be a bad T Case fork, since the failure rate is substantially below 25%, it is a whole bunch more likely you need to check the buttons and drive in reverse while attempting to shift back to 4 Hi, like others have mentioned.
If you can shift it into Lo Lock, and back to Hi Lock then you know that the T Case shift actuator is OK and rule out that potential issue.
Backwards turning to and fro while pushing the 4 Hi button should do it.
nncanfarelli
Aug 4, 2019 09:27 PM
HumRluvR
May 31, 2016 07:53 AM
knicholson
May 27, 2014 10:26 AM
FERRUCHI6
Jan 9, 2010 01:57 PM
Chameleon
Feb 4, 2009 11:16 PM
