H3 lift????
Old Jan 25, 2014 | 04:21 AM
willdoesstuff's Avatar
Default H3 lift????
Hey there, whats the biggest h3 lift you can get? U have the oldmanemu 2" lift atm but want to go bigger. Rancho does a 4" lift but is there bigger??
Old Jan 25, 2014 | 10:13 AM
staggs's Avatar
unless you go full custom the largest you can go is 4" roughly, and you could add a 1" inch body lift on top of that. Any particular reason you are wanting to go so big? Anything over a 35" tire causes too much of a strain on the drivetrain to make it a reliable logical daily driver and you can put on 35s with no lift, only cranking your torsion bars a little.
Old Jan 25, 2014 | 10:40 AM
staggs's Avatar
Here's mine on 35's with only the torsion bars cranked
Attached Thumbnails H3 lift????-20140106_160354.jpg   H3 lift????-20140106_160754.jpg   H3 lift????-20130413_133338.jpg   H3 lift????-20130522_170642.jpg
Old Jan 26, 2014 | 11:00 PM
Ok yeh, yours looks good, mine has factory flares on it and iv got a 2" lift with 33" tires and they rub when tight turning. I wanna go a big lift because it looks sick!!,lol might just do like you said, the rancho 4" with 1" blocks
Old Feb 2, 2014 | 06:09 AM
amrg's Avatar
I believe your rubbing on the sway bars. A lift wont solve this, less offset wheels or spacers wld. I have factory flares, running 35s and wheels with 28mm less offset than factory wheels. (wheels stick out more), and I barely get rubbing. A friend of mine is running 36mm spacers on stock wheels and 35s, no rubbing whatsover on the sway bar. But he needed a body lift to clear the fender flares.
Old Feb 2, 2014 | 10:51 PM
Nah. Mine rubb little on the bottom of the front mud flaps. Not sway bars. Are your 35" tites 315,75,16?
Old Feb 3, 2014 | 09:36 AM
amrg's Avatar
Well I had those before, now Im running 315/70/17 on less offset wheels. The T-bar crank solved the issue with them rubbing on the mud flaps.
Caraddict
Jul 3, 2014 01:11 PM
Brianb
Aug 20, 2010 09:09 AM
CruisinCarAudio
Jan 21, 2006 03:54 AM
stallioncustoms
Jan 14, 2006 04:42 PM
Pillario
16
Dec 29, 2005 10:42 AM
