h3 interior shift boot
Old Jun 27, 2015 | 12:35 PM
oh hum's Avatar
Default h3 interior shift boot
My auto interior shift boot is kind of ratty. I've found some vague,conflicting ways to replace it. Some say the forward console and shifter **** have to be removed. Another one said the shifter **** and bezel just have come off. Don't want to start yanking blindly. Thanks.
Old Jun 28, 2015 | 08:45 AM
wfturner's Avatar
You didn't say if you are referring to the manual transmission ?
If you mean the leather boot for the manual trans, then yes, the boot unclips from the front first, then there are two clips that are difficult
to unclip from the rear of the boot.
Once this is accomplished, the upper shift lever and the shift **** and the entire boot is one piece.
It can be removed by loosening of the allen screw, holding this assembly to the transmission shaft pin
Old Jun 28, 2015 | 11:56 AM
oh hum's Avatar
Thanks for your reply but I have an automatic. Am I in for a tougher time of it?
Old Jun 28, 2015 | 04:31 PM
wfturner's Avatar
I can't help on an auto trans. someone else will have to chime in.
I now see you did mention "auto", sorry
Old Jul 1, 2015 | 09:56 PM
Robert May's Avatar
The shift lever has a small bolt in the front of it. I think it might have been an hex bolt. Engage the parking brake chock the tires. shift it into first. remove the bolt pull up and the handle will come off. Open the center glove box and just pull up on the top portion of the center shift console from rear then work your way to the front. Then you can replace your boot. Install from the front to the rear working the boot over the shaft. The console clips back down. Reinstall your shift lever and you should be done. Don't for get the bolt.
Old Jul 19, 2015 | 09:06 AM
oh hum's Avatar
Update: First thanks for all the tips. Came apart easier then I figured. The problem was with the leather ebay boot I bought. Said it was made for an H3 auto. However, the leather was so thick it was murder tucking it into the plastic frame. Then the assembly would not fit into the the console opening because of the thick leather. I ended up paying more for the whole boot assy with handle and frame. 10 minute job that way. Only thing it's that cheap vinyl material. But it looks way better then the tattered one that was in there. Thanks again.
ff2024
Nov 4, 2023 09:39 PM
DirtyH3
Oct 4, 2015 11:31 AM
rsm688
Oct 18, 2014 01:53 PM
shortbus
Dec 21, 2007 01:38 PM
HummerGuy
Aug 7, 2006 02:44 PM
