H3 HP increase module question
Old Apr 24, 2008 | 03:08 PM
motley1987's Avatar
Default H3 HP increase module question
Being new to the group, I'm not sure if this topic has come up recently so I apologize if it's redundant. I have an 08 H3 and was looking to buy one of those HP increase modules the go into the AIT sensor. Looking at older posts, it seems the AIT and MAF are combined, so can I not use the module that plugs into the AIT when it's separate from the MAF and only has 2 plugs? I've seen a 4 plug module but wanted to make sure I understand the setup before I spend anymore money. Any information or suggestions of things I should try will help. Thanks!
Ben
Old Apr 24, 2008 | 03:13 PM
Default RE: H3 HP increase module question
PCMForless. They do a good job, lots of have the mod done, and I think it is the best bang for the buck.
Search PCMForless for reading.
Old Apr 24, 2008 | 03:15 PM
Steve #1's Avatar
Are you talking about the eBay snake oil resistor?
Old Apr 24, 2008 | 03:23 PM
ockie's Avatar
Go with PCMForless. Do not trust some lame HP promises by "adding" a mod. There are a few things going to get you the HP you want, PCMforless is one of them.
Old Apr 24, 2008 | 03:25 PM
motley1987's Avatar
That's the one. I don't know anyone that's used one and since they're usually cheap I figured I'd try one.
Old Apr 24, 2008 | 03:27 PM
Give the money to the homeless instead...it will be better spent. Lots of happy PCM4less customers.
Old Apr 24, 2008 | 03:33 PM
Steve #1's Avatar
ORIGINAL: motley1987
It will do more harm than good. Basicly it make the engine run like it is always cold. bad enough on a normal engine, and probably even worse on an engine with VVT. Could cause you to fail a smog test. yadda yadda yadda
Old Apr 24, 2008 | 03:48 PM
motley1987's Avatar
Cool, thanks for the help! I don't know how it took me so long to find this forum but I'm glad I did.
Old Apr 24, 2008 | 07:51 PM
ChevyHighPerformance's Avatar
The theory behind the module is that it alters the inlet air temperature (IAT) sensor's reading to the PCM. The module tells the PCM that the incoming air is colder than it really is. On some vehilcles, the PCM will add timing with the cooler air. Here is the PCM's IAT timing adder table for the I5 3.5L H3. You can see that at 104F and higher timing is removed, but below this temperature no timing is added. So a module will not work on this H3's PCM.
[IMG]local://upfiles/774/276B4232288443BB93C296AD1F843937.jpg[/IMG]
cmbowles
Jun 19, 2009 08:24 AM
fuzzi
17
Dec 13, 2008 07:57 AM
HummerGuy
Mar 16, 2007 01:03 AM
HummerGuy
17
Nov 22, 2006 02:28 AM
