H3 HP increase module question
Being new to the group, I'm not sure if this topic has come up recently so I apologize if it's redundant. I have an 08 H3 and was looking to buy one of those HP increase modules the go into the AIT sensor. Looking at older posts, it seems the AIT and MAF are combined, so can I not use the module that plugs into the AIT when it's separate from the MAF and only has 2 plugs? I've seen a 4 plug module but wanted to make sure I understand the setup before I spend anymore money. Any information or suggestions of things I should try will help. Thanks!
Ben
Ben
ORIGINAL: motley1987
That's the one. I don't know anyone that's used one and since they're usually cheap I figured I'd try one.
The theory behind the module is that it alters the inlet air temperature (IAT) sensor's reading to the PCM. The module tells the PCM that the incoming air is colder than it really is. On some vehilcles, the PCM will add timing with the cooler air. Here is the PCM's IAT timing adder table for the I5 3.5L H3. You can see that at 104F and higher timing is removed, but below this temperature no timing is added. So a module will not work on this H3's PCM.
[IMG]local://upfiles/774/276B4232288443BB93C296AD1F843937.jpg[/IMG]
cmbowles
Jun 19, 2009 08:24 AM
fuzzi
17
Dec 13, 2008 07:57 AM
HummerGuy
Mar 16, 2007 01:03 AM
HummerGuy
17
Nov 22, 2006 02:28 AM
