H3 Alpha transmission out
Old Jul 23, 2015 | 01:59 AM
reignla's Avatar
Default H3 Alpha transmission out
My transmission went out at 104k miles. 2 weeks ago, I noticed it slipping on the freeway when it was at 55mph and going uphill. Took it to the dealer who said there were no problems. One week later, it completely went out on the freeway. It would not shift out of first and if I pushed it to (so I could get out of traffic), the engine started getting hot. Is my hummer ever going to be the same? What transmission brands are good? Am I in a losing battle?
Old Jul 24, 2015 | 08:17 AM
Old Jul 24, 2015 | 12:53 PM
rsc's Avatar
rsc
The best transmission you can get is from PATC, a Raptor Level 3 transmission is a good one. You could get the parts from them for a rebuild to the same specs. The LKQ transmissions go for around 1K!
Old Jul 24, 2015 | 07:27 PM
H3Ray's Avatar
Exclamation
GET OUT WHILE YOU CAN !!! ... Buy the Jeep SRT or Toyota Tundra!
Old Jul 25, 2015 | 01:09 PM
amrg's Avatar
Ignore the idiot above!
My friend owned a JEEP SRT, off the dealer lot, it had transmission problems. Took it to the rep, he persuaded him it will go after the car breaks in.
long story short, 3 dealer visits to get the truck repaired, stayed 2 months with them, problem got solved when the dealer took back the car and re imbursed my friend.
Trans problems at 105K doesnt mean sell the truck.
Old Jul 25, 2015 | 02:10 PM
Ignore the idiot above X2.
The best trans will be one rebuilt with all new parts by a certified tech. Shop around. If you have the $ check out shops that use the monster sun shell to replace the weak OEM one.
Good luck, let us know what you decide on.
Old Jul 25, 2015 | 11:10 PM
rsc's Avatar
rsc
The sunshell is $45-50, an easy upgrade for any shop that has it apart and a standard upgrade part. Luckily the H3 already has most of the regular longevity upgrades from the factory.
Old Jul 26, 2015 | 05:08 PM
H3Ray's Avatar
The Jeep SRT is the H3 but stronger and way more reliable in every way.
Old Jul 26, 2015 | 07:49 PM
reignla's Avatar
Thank you for the valuable info. After a ton of investigation, I found a reputable transmission specialist. I asked him about the sun shell and he said he would re-quote the price with the upgrade for me. He said he usually uses sun shell on high performance vehicles but he has no problem using it on my H3. The original quote to rebuild my transmission is $1500 so I'll see what he charges using the sun shell. Anything else I should ask?
Old Jul 26, 2015 | 10:50 PM
rsc's Avatar
rsc
The price difference between a standard and a heavy duty rebuild is not that much. You should already have the 13 vane pump, a Corvette servo is under $50, read up on and decide if you prefer Borg Warner, Alto or Kolene friction disks and steels, an upgraded kevlar band is inexpensive and has pros and cons but it does have holding power and maybe look at a bearing and bushing upgrade kit if you have more left to spend. If running 35's or doing any towing, especially with high summer temperatures, I would recommend the HD built. Oh yeah, get a big 24k lb rating or bigger trans cooler with an in line bypass thermostat.
