H3 with 26inch... any braking problems? or ride stiffness?
Old Jun 6, 2009 | 01:30 PM
xxterxx's Avatar
Default H3 with 26inch... any braking problems? or ride stiffness?
anyone here is using 26inch for the h3?
anyone found the ride harsh? or reduced braking power due to larger circumference...
thanks
Old Jun 8, 2009 | 10:47 PM
stubbsy's Avatar
I run 22's with 305/40/22 tyres and the ride is a bit harsh and does wander a bit under heavy braking but its a trade off for the look.
I guess you are looking at the wheels on EBay, if I lived in the States I would buy them.
Cheers.
Old Jun 10, 2009 | 07:52 PM
hilgy125's Avatar
Default H3 with wheels
I have my 08 sitting on 24's with 305/35's the ride didn't seem to change a lot, but it is noticable. The look however well out weights the slight lose of ride.
Old Jun 11, 2009 | 10:42 AM
xxterxx's Avatar
any problem with braking? any pics of your ride? i want to see how 24s look like on the H3
Old Jun 12, 2009 | 08:05 AM
D VADER's Avatar
When ever you increase the diameter of your wheel you loose Horsepower, braking and ride.
IMO the biggest you want to go is 20". With 26" you should increase the diameter of your rotors and bigger calipers.
Bob
Old Jun 12, 2009 | 02:50 PM
hollywould's Avatar
Default Rim pics . . .
Check out http://www.cardomain.com/MakeModel/Hummer/H3 for pics of H3's w/ rim packages. They had one on 30's. Don't know where it went, though. Guess they deleted it.
Think 24's are just about the biggest you'd want to go. Rode in one with 22's and it felt real clean. Had 285/45/22. Think the 22's look nice with the lowering kit. 24's even better! Whatever rim you go with, you might as well drop it, too. Not like you're gonna be going off-roading any longer.
Old Jun 12, 2009 | 03:12 PM
Hummer Guy's Avatar
With 26inch wheels you will dramatically decrease ride quality.
Old Jun 21, 2009 | 03:56 PM
bunny2121's Avatar
I ride with 24's on my H3 and have not once had an issue with a "bad ride". One can say putting mudders on a H3 will give you a "bad ride". Im my opinion the handling is better since the wheels are larger then the narrow stock rims. Horsepower?? whats that with a H3 I5 engine? I will agree that sudden braking is lost but not by much. You will "eat" brake pads alot quicker then you would having the stock wheels. I rode with 26's before i bought my 24's and to me it looked like crap..rims stuck way off the sides of the fenders looked very stupied. Make sure whatever size rim you go with it is the "correct" offset for your truck. Alot of people figure since the rims are "6 hole chev pattern" they'll work..WRONG! do your homework before you spend your money..I have pics posted here with my hummer on 24's
Old Jun 27, 2009 | 08:46 PM
hollywould's Avatar
24's all damn day. Stay away from the 26's.
Old Jun 28, 2009 | 07:39 AM
H3Tex's Avatar
Default 16" is all you should go
Do not go any bigger than 16" wheels. With this size it allows you to lower the pressure in your tires which allows them the conture and grab the rocks you are going to climb better. With a low profile tire you really hurt the vehicles ability to offroad.
H2zona
Aug 6, 2018 06:31 PM
itsxthexslim
Apr 7, 2012 11:04 AM
XxCC3xX
Aug 23, 2011 02:05 PM
Brian C D
Mar 23, 2010 07:30 AM
xxterxx
Jul 14, 2009 02:02 PM
