H2 straight pipe / test pipe
Old Oct 26, 2014 | 08:04 PM
damienh2's Avatar
Default H2 straight pipe / test pipe
Hello,
I apologize for not posting on this forum as much as I should be, but I use this board as a great reference for the last 5 years. I finally ran across a problem which I could not solve through search. Many of you are running no cats and using straight pipes. I have ran test pipes, off road h/x pipes in the past on different cars where the cat was eliminated but these pieces were perfectly fitted to the car with gaskets and flanges. I am not really finding one for this platform. I am having too many problems with these cats to the point they have to go. I could go the route of a custom job, but if a perfectly fitted piece exist could someone point me in the right direction. Thank you in advance.
Old Oct 27, 2014 | 08:09 AM
calif phil's Avatar
I think they are illegal now and no one sells them.
Old Oct 27, 2014 | 08:21 AM
Indy's Avatar
Just get a high quality high flow cat...they flow almost as well as a test pipe, and they're legal in most states.A good cat should last you a long time.
Old Oct 27, 2014 | 08:30 AM
damienh2's Avatar
They never were legal were road use. However, high flow cats. Where is the recommended list?
Old Oct 28, 2014 | 09:34 AM
Circuitguy's Avatar
You need to run cats on these engines, the back pressure is needed to run properly. Every Hummer H2 owner I know that had them removed had nothing but problems with the computer and sensors. I do not recommend that you remove them.
jayhawk714
Oct 4, 2011 12:17 PM
Tech5
Mar 13, 2011 03:23 PM
bimmen04
Aug 29, 2010 12:26 PM
Fennsz
19
Jul 16, 2010 01:40 PM
psych0
May 10, 2010 09:14 AM
