H2 rear suspension sagging....
Old Sep 3, 2008 | 01:46 PM
RedWood's Avatar
Default H2 rear suspension sagging....
I have an 03 h2 with the infamous air ride suspension. I do have a 6.5 fabtec lift, but i have extended arms on the sensor to compensate for the lift. I recently towed a car 700 miles. After i had been home for a couple days the entire rear end is sagging. I had previously had the same problem with the passenger rear side sagging, but not both sides. when that happened i was also getting the "service air suspension" code. I took it to the dealer and they installed a brand new airbag and spring costing me near a grand (not to sure if i want to do that again).
This time both passenger and driver rear is sagging and no code. I vaguely remember the air compressor running and evacuating air constantly before it sagged completely. Any troubleshooting suggestions???.... Ive read that it could be a hose or the airbag, but with no code and the compressor not kicking on what else can i do to be sure. just to let you know, i bought 1 new sensor and installed it on both sides to see if it would make a difference and i unplugged the battery for about 20 minutes, neither did any good.
thx
Old Sep 3, 2008 | 02:44 PM
TRUBRIT's Avatar
Default RE: H2 rear suspension sagging....
Check here for an option. Maybe contact this Guy.
http://www.hummerxclub.com/forum/vie...f=3&t=8486
Old Sep 3, 2008 | 04:18 PM
RedWood's Avatar
thanks for the reply, I ended up lifting the vehicle and sure enough the new air bag and air spring i replaced was not attached to the frame, and the airbag had no air in it. Off to hummer i go for the 12k warranty on the part.
Old Apr 27, 2009 | 04:01 PM
Strutmastr's Avatar
It sounds to me like your compressor got killed. What probably happened is that the airbag got a hole or tiny crack in it so the compressor has to work extra hard because it is like blowing up a balloon with a hole in it. Therefor the airbag will kill the compressor. I would recommend going to strutmasters.com and taking a look at our conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. This is a PERMANENT fix and ALOT cheaper than going to the dealership. I added the link below so you can check it out.
http://www.strutmasters.com/hummer-h...nsion-s/97.htm
I hope I was of some help
Good Luck!!!
Old Apr 28, 2009 | 01:44 PM
calif phil's Avatar
How is the ride with your conversion compared to the stock air ride. I like the way my H2 rides now and I have no problems with my air ride right now. I am just asking in case mine goes bad. What happens with the compressor, sensors and the computer once you install your springs?
Old Apr 30, 2009 | 01:50 PM
mfish's Avatar
I was wondering that too. It seems if you unplug and remove the bags and compressor you may get a error message from the computer?
rockstarbass1
Jan 2, 2015 09:52 PM
driver
Oct 2, 2011 04:06 PM
Indy
Mar 7, 2011 08:33 AM
th3_villain
Oct 7, 2009 08:38 AM
beezer34_ca
May 8, 2007 12:26 PM
