H2 Fog light switch, need help with a question
Old May 19, 2016 | 10:17 PM
reeves4744's Avatar
Default H2 Fog light switch, need help with a question
I am new to the hummer world, I'll be picking up my 2008 SUT on Sunday and I'm pretty excited.
I read in a post where citiboy used an GM Arcadia switch to solve his fog light switch dilemma.
My question is how did he solve the windshield washer switch since it is not included with the GM Arcadia switch.
Thank you
Old May 20, 2016 | 07:42 AM
citiboy's Avatar
hey reeves, my truck never had the option for the heated windshield washer but, i installed one from Alphatherm that doesn't need a switch to activate (AlphaTherm Heated Wash AT-37GM is direct replacement for ALL factory installed General Motors “GM” heated washer fluid modules). check the heated windshield washer system if it is still working, gm did a recall on it (GM Will Deactivate Heated Washer Fluid Systems). if not, then you can do the same mod like i've done.
if you still want to retain the oem headlight switch then, this is the other alternatives for the accessory light switch. scroll down to post #26 for pictures. you have to relocate the onstar and sunroof switch though.
Switch mounting ideas - Page 3 - Chevy and GMC Duramax Diesel Forum
hope this helps! oh, and welcome to the hummer family \m/
Old May 20, 2016 | 09:45 AM
reeves4744's Avatar
Default Thank you
Thank you so very much, you have been a huge help; more importantly my OCD for things being "just right" has been satisfied (for now)
I may ask for your advice / help once I start driving it, if that's OK?
Again, thank you very much.
Sincerely,
Robert Eric Reeves
Old May 20, 2016 | 10:10 AM
citiboy's Avatar
ask away...that's why we here for. enjoy your awesome truck!
Old May 22, 2016 | 09:44 PM
reeves4744's Avatar
Default Leveling Kit
Absolutely LOVE my truck, picked it up today. Throughly impressed with the smooth ride, comparable to my Yukon.
Can you recommend a leveling kit where the smooth ride will not be sacrificed (if possible)
Or should I leave as is?
Thanks again for all of your help.
Old May 23, 2016 | 08:23 AM
MOVED to the H2 section, where.......
.......................questions about H2s go.
The HF Help & Suggestion section is for questions on how to use the forums and has nothing to do with any vehicle.
Old Jun 2, 2016 | 02:22 PM
reeves4744's Avatar
Default Fog Lights Part II
Citiboy,
I purchased the Arcadia switch as recommended, however the technician is having difficulty making it work. As i understand it, since the dealer de-activated the water bottle heater there isn't a way to bypass the Control Unit and isolate the Fog switch to act as desired.
Can you tell me how you overcame this so i can instruct the technician?
Thank you so very much.
Old Jun 2, 2016 | 04:26 PM
citiboy's Avatar
Hey Reeves,
You can start reading beginning post #7 from this thread. Any info that you need are already been discussed there.
https://www.hummerforums.com/forum/h...stalled-33458/
Good luck!
dbetler
May 14, 2020 11:03 AM
MH3
Nov 25, 2014 08:01 PM
JCsh2
34
May 6, 2013 10:00 PM
lucky19942001
May 20, 2008 02:41 AM
WhtRatCop
Jun 22, 2007 03:02 AM
