fog light install help (wiring)
Old May 16, 2008 | 07:34 PM
lucky19942001's Avatar
Default fog light install help (wiring)
need a little help here.gonna install some piaa fog lights on my brush guard and for the most its a pretty straight forward process.the only thing i am not sure about is one wire.this wire is to power the on/off switch.this is what it says. find a power source to connect the switch wire to. for fog lights this power source must be one that is only powered (+) when the low beam of the headlamps is on. make connection with supplied connector. if it helps the wire is white.
[IMG]local://upfiles/4035/65124DB7540242DEAAE871C7F69C868E.jpg[/IMG]
Old May 20, 2008 | 02:41 AM
Steve #1's Avatar
Default RE: fog light install help (wiring)
ORIGINAL: lucky19942001
At the BCM (passenger foot well) BLACK plug pin A2 (when you look at the back of the plug where the wires go in it will be lower left one row up) Yellow is the fog light relay control.
If you prefer to tie them in with the low beems it is pin A5 which is pink/white
Double check to make sure they are 12V +.
AR15wheeler
16
Feb 16, 2016 10:42 AM
Best4x4
May 2, 2013 08:37 AM
Thumper
Mar 18, 2013 12:03 AM
meanh1
Oct 25, 2012 07:36 AM
mstnangsherry
Nov 11, 2010 12:18 PM
