H2 with Check Engine Light On - Help Please
Old Feb 16, 2015 | 03:13 PM
oceanbrave's Avatar
Default H2 with Check Engine Light On - Help Please
Based in UK, just bought a H2 a week ago, all was going great until the Check Engine Light came on (permanently, not flashing)
Bought a Vgate Scan OBD Scan Advanced OBD Scan tool but it wont work with the H2 however it does work with VW Golf & Passat so it must be a Hummer compatibility issue.
Can anyone recommend an OBD Bluetooth device that is known to work with the H2?
I have just a few days to return the vehicle if I'm not happy with it, must confess to being slightly worried, having said that it seems to run fine.
Any help would be very much appreciated.
Old Feb 16, 2015 | 08:48 PM
dr.drew2's Avatar
first check gas cap.
second any obd2 scanner works.
third it is common to see code po449 which is evaporative canister leak small. it on frame and common.
Old Feb 16, 2015 | 08:49 PM
dr.drew2's Avatar
if it wont scan check the fuse under the hood in the fuse box
Old Feb 17, 2015 | 04:21 AM
oceanbrave's Avatar
Default OBD Reader
Thanks for the suggestions, certainly will look at them.
The OBD reader was an Elm 327 but could be a cheap copy so its questionable. Fuse-wise I can see lights on it, gonna call in a service center later today and get a professional scan then we'll know.
Will post results when I get then.
Old Feb 17, 2015 | 04:59 AM
LoJac963's Avatar
The ELM327 works fine on mine, that's odd it won't work on yours. Is it getting a link between your phone or tablet-whatever you're using?
Old Feb 17, 2015 | 03:32 PM
oceanbrave's Avatar
Default ElM327 & fault Resolved
Firstly, took the H2 to an auto expert, good news is that the ODB port was OK.
The fault was P0420 "Catalyst System Efficiency Below Threshold Bank 1"
Anyone familiar with this one?
Re Elm327
Like I mentioned it worked fine with my VW Golf and VW Passat, just didnt like the H2. Perhaps its defective or a cheap copy, seems clear that a good diagnostic tool is invaluable so will try another.
Old Feb 19, 2015 | 06:28 PM
ant69's Avatar
Bad Cat! looks like you'll need to call Magnaflow
Old Feb 20, 2015 | 03:16 AM
oceanbrave's Avatar
Default Re Bad Cat and ELM327
Indeed or it could be or a sensor, I'll keep monitoring now I have new and working ELM327 ... yay!
There is a lot of Andriod ODB2 software out there, is there a really good app that works well with hummers?
Poweraidion
Feb 16, 2014 11:26 AM
joenuzz
Aug 21, 2010 10:24 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
markushp
Jul 17, 2009 02:22 PM
MRDM1
Oct 26, 2007 08:24 PM
