check engine light is on HELP
Old Oct 2, 2007 | 10:43 PM
MRDM1's Avatar
Default check engine light is on HELP
yesterday i turned my truck on via the remote start and it did turned on but one i put the key in it the truck turned off and i try using the key to turned back on and the check engine light turned on i try turning it on and off and nothing so i drove it home and on my way home i stop at burger king and check the engine oil and when i went back inside the truck and turned on the light didnt turn on SHOULD I BE WORRY ABOUT THIS MY TRUCK HAS 63,400 MILES ?
Old Oct 3, 2007 | 09:32 AM
HumminNBoatin's Avatar
Default RE: check engine light is on HELP
Just go to Autozone and have them pull the code. If you have plenty of oil and oil pressure you will be safe to drive it. Just so you know the Check Engine light can mean a thousand different things.
Old Oct 3, 2007 | 05:47 PM
MRDM1's Avatar
the funy thing is that it has been off since
Old Oct 3, 2007 | 06:43 PM
Muddydawg75's Avatar
In my experience Check Engine is almost always something to do with emissions.....
Old Oct 4, 2007 | 08:34 PM
saywhat's Avatar
I had this problem with remote start and I would pull the positive battery cable for about 30 min. and it would reset. It only happen to me when i used the remote start when it was Hot 85 plus!!!
Old Oct 5, 2007 | 01:43 PM
hilljob26's Avatar
did you just get gas,did you not twist the cap enough,it will do it
Old Oct 26, 2007 | 08:24 PM
MRDM1's Avatar
i got it it was the baterry that had to be replace
oceanbrave
Feb 20, 2015 03:16 AM
Poweraidion
Feb 16, 2014 11:26 AM
joenuzz
Aug 21, 2010 10:24 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
markushp
Jul 17, 2009 02:22 PM
