H2 ****fer stuck in Park Bigger issue than Wires
Old Apr 27, 2016 | 04:52 PM
  #21
Jeff Bartnett's Avatar
Like I said in previous post, I even cut the green/white wire to eliminate any voltage and the white button still didn't release without some pressure.
Old Apr 27, 2016 | 05:21 PM
  #22
HUMTECH's Avatar
Do you have a electric brake controller hooked up?
Old Apr 27, 2016 | 05:40 PM
  #23
HUMTECH's Avatar
You said you replaced brake lamp switch? Where was switch that you replaced located?
Old Apr 27, 2016 | 05:43 PM
  #24
No electric brake controller. Brake lamp switch was located where brake pedal lever and linkage meet under dash
Old Apr 27, 2016 | 06:03 PM
  #25
HUMTECH's Avatar
If you have the connector at shifter(6 pin connector) disconnected and you have 8v on green white wire with brake pedal pressed the only way voltage is on that wire is either through brake switch or that wire is shorted to power somewhere. Did you put a new brake switch in or a used one?
Old Apr 27, 2016 | 06:46 PM
  #26
Ok. But if I totally cut the green/white wire so there's no voltage on that wire at all at the connector, why won't that button smoothly release when it has no voltage??? It should work but it does not.
The other thing happening is at the ignition. If I have vehicle in park and no foot on brake the key only shuts off to the first position. If foot is on brake and engine running it will release all the way. Somehow the two things are related I suspect.
Old Apr 27, 2016 | 07:08 PM
  #27
New brake switch. ACDelco
Old Apr 28, 2016 | 06:03 PM
  #28
The fun continues...
Decided to replace the Neutral Safety Switch and lots of problems. First, the Shifter vs dash display of transmission gear not in sync. So I know the NSS is positioned to neutral to install. Should the tranny be in park or neutral when I install?
Hopefully once I get that in sync it will work but right now I'm not getting click on the Shift lock Switch.
Old Apr 29, 2016 | 10:40 AM
  #29
Conclusion...I'm pretty sure the issue in the end was the Park Neutral Safety Switch. Old one had some play in it and was probably causing the Shifter Lock Solenoid to not fully disengage.
steeleclipse
May 29, 2025 09:54 PM
DZLROKET
Aug 23, 2019 10:01 PM
HumRluvR
May 31, 2016 07:53 AM
jlstrick07
Mar 27, 2011 03:38 AM
howdy301
Jan 23, 2007 09:19 PM
