Grinding noise 4 whl low
Old May 27, 2008 | 03:47 PM
IHNEVELS's Avatar
Default RE: Grinding noise 4 whl low
What i did the last time was with out moving i engaged 4 low shifted into rev./nut/dr then reversed the process stopping at each for several seconds then to park without moving an inch. thats what has me so puzzled.
Old May 27, 2008 | 03:51 PM
rhill20's Avatar
Hopefully they will be able to figure it out then. Maybe your pressure plate isn't engaging correctly
Old May 27, 2008 | 04:28 PM
I have had that noise before also and had no ill effects so far.
Old May 29, 2008 | 09:26 AM
RealJeep's Avatar
Isn't this Borg Warner T-case shifted by a little electric motor with plastic gears? If so, then it may have some goop gumming it up and not making the trip all the way back to 4Hi. Just a thought...I MISS my shift levers!
Old Jun 4, 2008 | 12:28 PM
IHNEVELS's Avatar
UPDATE,
Dealer called today and said they pulled transfer case 3 times, pulled transmission tore down and replaced some worn parts. still has the same noise. they said they have 3 06 models there and that all three do the same thing. Idk. they did tell me it is probably due to the motor being torqued up so tight that if i go from nutrual to park it does not do it.they also said that if it fails they will replace complete tranny. sounds like bs to me but its at their expense.
Kinder82
Apr 4, 2013 08:30 PM
bimmen04
Aug 29, 2010 12:26 PM
Oldyeller
Apr 6, 2010 09:17 AM
racegun
Nov 26, 2009 10:42 AM
quadblaster240
Oct 16, 2009 07:51 PM
