Gearbox swap computer re-learn??
Old Oct 26, 2022 | 09:23 PM
Bonairesurf's Avatar
Default Gearbox swap computer re-learn??
Hi everyone,
I own a 2008 Hummer H3 that has a bad transmission due to a radiator failure resulting in coolant and transmission oil mix.
I did a full flush and replaced filter but ended up losing 3rd gear.
Unfortunately where I live there is no expertise to rebuild - so I will need to replace.
- Can I just replace my current transmission with any year H3 or Chevy Colorado? ( 2006-2009 )
- And just as important, does anything need to be re- programmed on the vehicles computer?
I really love my H3 and my wife has one as well. Had them shipped from Florida to the Southern Carribbean.
Any info is well appreciated.!!!
-Sebastian
Old Oct 26, 2022 | 10:14 PM
brothapig's Avatar
Don't know about the programming, but the H3's have a unique transmission pan that has a cut out for the front drive shaft. I believe you can just swap pans on a compatible transmission.
Old Oct 27, 2022 | 09:07 AM
Any 4L60E Trans 2000 - 2010 from any GM truck would work so long as you use the H3 Trans Pan like brothapig said. I am sure 1996-2000 years would also work. Should be plug n play, no programming so long as the replacement is a stock replacement or rebuild. If internal changes/modifications different from OEM were made, that might need to be addressed.
Old Oct 27, 2022 | 03:47 PM
Ordieh's Avatar
The valve bodies are unique and there are more than one!
HummerH2
May 24, 2026 06:41 PM
Blackhummerh3v8
Dec 19, 2020 11:14 AM
maximoxxdi
Nov 30, 2020 05:10 PM
Gemini 64
Mar 24, 2020 11:18 PM
faresmotors
24
Dec 19, 2017 02:09 PM
