FYI, Engine Code P0171
Old Jul 23, 2013 | 01:31 PM
  #21
Mighty455's Avatar
Originally Posted by Mannyfresh79
Did the light came back on with the addition of gumout
Sorry for the late response. Yes, it did resolve the issue.
Old Feb 20, 2015 | 01:05 PM
  #22
djl1qu1d's Avatar
I just had Sears do an oil change and change my plugs at ~96k w/ Iridium and Platinum plugs. I am now getting the P0171 error when I didn't before.
P0171 DTC: System Too Lean
I guess I'll check my K&N and then call Sears.
Old Feb 20, 2015 | 01:58 PM
  #23
First: This thread is OLD.
Next: If sears did not use AC Delco plugs, then you just wasted $$ on having them put in crap that will be fried in short order. This has been said here and at other Hummer, Colorado and Canyon forums before: If you have an I5 do not use anything but AC Delco plugs or you are asking for trouble.
Old Mar 6, 2015 | 10:47 AM
  #24
djl1qu1d's Avatar
All I did was use Search. It's not like I spent hours digging thru old posts. Anyways, I did have Search swap out the plugs for AC Delco Iridium.
I still am getting the error though.
I noticed people were saying to look at the intake, MAF, etc. The fat foam seal that goes out to the firewall seems fine and the intake box where my K&N is seems fine.
I did notice that there's a hose up near the hinge of my engine that was just sitting there. "1/2 GM6148-M 090505 AGB'. It seems like it could be the air intake vacuum line. Whether it's actually from my car or not we'll see but I think it's likely the culprit as people were saying it's possibly a vac leak.
Does this hose look familiar to anyone?
it's pretty strange as the car seems to run ok.
Old Mar 6, 2015 | 12:01 PM
  #25
That hose was from the stock intake (underneath rear of the resonator box) to the breather port at the rear of the valve cover. Whoever put on your K&N must have left it there.
K&Ns also have a rep for cracking, cracks leak.
The intake manifold bolts that fasten it the head have been known to vibrate loose and cause a leak.
Old Mar 7, 2015 | 09:28 AM
  #26
djl1qu1d's Avatar
Interesting. Thanks!
Old Jun 26, 2015 | 07:28 AM
  #27
Cdrcrash's Avatar
Check your breather hose. Mine was disconnected.
Took a Zip tie and locked then hose to the box, then slipped the other side to the crankcase port. No more code and an easier install.
Old Jun 27, 2015 | 08:50 AM
  #28
djl1qu1d's Avatar
Yup for me it was the hose. somehow one of them took it off when doing my plugs. they put it back on and everything was fine again. thanks
Nate2106
Mar 14, 2019 12:03 PM
jerferg
Oct 28, 2013 03:23 PM
Alex2012
Oct 1, 2012 01:53 PM
user 956363738
Jan 19, 2012 10:14 AM
ken haukaas
Jan 11, 2011 08:14 PM
