Front Wiper Problem only works on high :(
Old Feb 7, 2011 | 03:31 PM
HumV's Avatar
Default Front Wiper Problem only works on high :(
One day my wipers stopped working correctly.. after the ice storm.. and yes I left the wipers on so once I started the car the wipers turned on and pushed the snow and ice.. For some reason they only now work on High all the other delays and low do not work.
I checked all the fuses related to the wipers and they are all good. I suspect it maybe the high/low relay . I called my dealer and they said its probably the motor . Well I passed the 50k warrenty and they are gonna charge couple hundred dollars to fix it. Does anyone have a similar problem and or has gotten there’s fixed? I am not sure if this is a relay or diode problem. When I change the switch from high to a lower position the wiper stops anywhere and does not park back home. When I put the position to the down below the low speed it goes on and stops where it pleases. I am pretty much driving with my wipers in field goal position.. very annoying.
Any troubleshoot or ideas will help thanks..
Old Feb 7, 2011 | 06:39 PM
drtom's Avatar
Banned
Default caution!
b4 anything else, do not mess with the mechanism with batt connected. i u move the motor drive arm and your fingers are in the way U CAN BE CRIPPLED,,, IF IT MOVES PAST THE PARK SW IT CAN TAKE OFF,A WITH TREMENDOUS POWER.
believe someone who has been there with headlight motors!! these geared down motors cant be stopped.
that said, ill look to see if the book has any help, or someone will show up
edit, like everything in h3 the wiper circuits are messy, complex. a guess would be relay73. it looks the same as rel 72. if u swap them and ANYTHING CHANGES, ID CHANGE REL 73. buy one, then u can swap it.
for some reason the ac clutch diode is in that circuit, dont ask me why, its messy.
Old Feb 8, 2011 | 07:55 AM
HumV's Avatar
Thanks Tom,
ill try the swap and let you know what happens
Old Nov 5, 2014 | 05:48 PM
ssanders11's Avatar
Default H3 Wiper issues like others...no parking
Originally Posted by HumV
Thanks Tom,
I swapped the relays too...no help...is it the motor or BCM?
something else?
Old Nov 6, 2014 | 11:31 AM
something else?
Something else.... from three almos FOUR YEARS AGO?
Wipers have High split off from the lower settings (2 circuits).
https://www.hummerforums.com/forum/n...bumping-23220/
Please do not dig up old threads.
MJN
Jan 5, 2015 01:55 PM
danaw
Oct 18, 2014 10:58 PM
carlosorama
Dec 6, 2008 09:18 AM
steves05h2t
Jun 10, 2008 11:44 PM
pduffy
May 3, 2008 05:51 AM
