Front end squeaking
Old Jun 7, 2008 | 06:25 PM
cyp10's Avatar
Default Front end squeaking
I am assuming I need some lube on the front end. Whenever I am driving I have a squeak on the front end whenever the truck bounces up and down. Anyone else had this problem? Anybody know where this squeak may be coming from and where to apply the lube? Thanks.
Old Jun 7, 2008 | 07:39 PM
solarflare's Avatar
Default RE: Front end squeaking
my shocks squeaked on my 3.....it was really annoying....
Old Jun 7, 2008 | 11:15 PM
rhill20's Avatar
No squeaks here. First guess would be a lube job as mentioned. Second, have you checked to make sure that you don't have anything rubbing?
Old Jun 8, 2008 | 09:55 AM
cyp10's Avatar
thats what i think it might be. any remedy?
Old Jun 8, 2008 | 07:48 PM
RealJeep's Avatar
Lube job? There's nothing user servicable under the H3 for you to lube. The best you can do is get a can of WD-40 and soak down anything rusty under the truck. Pay attention to sway arm bushings and other rusty parts thatrub each other. WD-40 is non residual and won't pick up a bunch of dirt so don't worry about it, just keep it off your rotors!If and when the squeak stops you can reapply as needed or do a repair if you find a worn bushing or part.
Cbenn17
Jan 12, 2014 07:20 PM
MattN
Feb 8, 2013 04:45 PM
quadblaster240
Dec 19, 2009 03:50 PM
brandon4589
Nov 25, 2007 02:25 PM
buzzwohl
Sep 29, 2007 08:27 PM
