Rear End Squeaking Sound
Old Jan 3, 2014 | 10:38 PM
Cbenn17's Avatar
Default Rear End Squeaking Sound
I have searched the forum and could not find anything specific to this. Over the last few weeks, I have noticed a pretty high pitched squeaking sound at different highway speeds. It is coming from underneath the H3 and was first noticed at slow speed when putting power to the rear wheels just driving around town. I am now hearing it at highway speed intermittently. My first thought was the right rear wheel/hub assembly because it does seem to come from the right rear, so as soon as I heard the sound, I immediately shifted into neutral and the sound went away. As soon as I put it back in drive and hit the gas pedal, it came back (did this at 55mph). It sounds like rear end issues or driveshaft.
Any ideas?
Old Jan 3, 2014 | 11:06 PM
happythree's Avatar
it reminds me of dried out u joint needle bearings.
even at a crawl they will squeak.
Old Jan 4, 2014 | 03:32 PM
Chameleon's Avatar
I had a squeak coming from the rear a couple of years ago, and then when my friend bought his H3 he had the same noise I found it on mine suggested it to him and it was the jack squeaking away in the rear door.
Just because you hear it under power and not when you slip the tranny into neutral would eliminate the jack, Open it up, move it around and tighten it up.
Go for a ride. I hope that is your problem and nothing more involved. Good luck.
Old Jan 9, 2014 | 10:48 PM
BmEcko21's Avatar
I've had the squeaky noise in the back, it was the jack.
Old Jan 10, 2014 | 10:46 AM
HUM3LE's Avatar
It could be as simple as the wheel bearing. Wheel bearing noise isnt always constant. Check that first. Or a garage might try to replace alot more. These trucks are bad for wheel bearings. Oh! And everything else too.
Old Jan 10, 2014 | 11:36 AM
happythree's Avatar
simply not true, made up.
Old Jan 10, 2014 | 09:08 PM
skeeter's Avatar
check the sway bar bushings
Old Jan 11, 2014 | 08:28 AM
biggjohnson2k's Avatar
Default Rear U-Joint
I had the same problem, ended up being the rear u-joint. EASY FIX!
Old Jan 12, 2014 | 06:06 PM
Cbenn17's Avatar
Thanks for the input guys...it was the rear u-joint on the drive shaft. The front one was heading south too, so I replaced both of them. Much better now.
Old Jan 12, 2014 | 07:20 PM
happythree's Avatar
so, do the things have grease fittings? I never looked and the mess outside, well you know!, anyone know?
I rear some new veh take a needle thru rubber type grease method.
MattN
Feb 8, 2013 04:45 PM
Zack'sH2
Aug 11, 2011 03:27 PM
cyp10
Jun 8, 2008 07:48 PM
brandon4589
Nov 25, 2007 02:25 PM
buzzwohl
Sep 29, 2007 08:27 PM
