Engine Warning + AC off
Old Mar 8, 2010 | 09:11 AM
FranzSchwe's Avatar
Angry Engine Warning + AC off
Dear Hummer friends,
Trouble with my brandnew Hummer H3 ,
since today "Engine Warning " light and in the Display the words "AC Off ".
any help ??
Thank“s to all
Franz
Old Mar 9, 2010 | 08:55 AM
calif phil's Avatar
Sounds like it was overheating. Was the temp gauge in the normal range?
Old Mar 9, 2010 | 12:35 PM
FranzSchwe's Avatar
everything in normal range, drives as before
Old Mar 9, 2010 | 12:51 PM
Hunner's Avatar
Did it not go in "limp" mode and not allow you to accelerate?
If you are sure it did not overheat sounds like a sensor problem. See your dealer.
If it displays that and shuts down the ac and goes in limp mode that is to protect the engine. It will shut down some cylinders from firing and only pump air to cool it down.
Better get it checked under warranty.
Old Mar 10, 2010 | 03:38 AM
FranzSchwe's Avatar
Hi,
the car did not go into "Limp" mode, everything seems normal.
I think i got he conclusion:
the car is equipped with a auxiliary heating system, if that thing
is turned on in winter approximatly 30 min prior starting, the sensors get
false readings,
the problem ist that the engine warning keeps on glowing, even if the
situation is cold again.
greetings from Germany
Old Jan 13, 2011 | 08:10 AM
thunderwolf's Avatar
i got the problem that you talking about. can you say what could it be?
Hummer_SG
Jan 28, 2026 04:44 PM
Champ53
Jul 19, 2011 02:26 PM
deejaykaygee1
Jan 20, 2010 04:57 PM
augustin01
Jun 18, 2008 06:07 PM
skeeet
Oct 18, 2006 12:51 AM
