Engine Warning + AC off
Did it not go in "limp" mode and not allow you to accelerate?
If you are sure it did not overheat sounds like a sensor problem. See your dealer.
If it displays that and shuts down the ac and goes in limp mode that is to protect the engine. It will shut down some cylinders from firing and only pump air to cool it down.
Better get it checked under warranty.
Hi,
the car did not go into "Limp" mode, everything seems normal.
I think i got he conclusion:
the car is equipped with a auxiliary heating system, if that thing
is turned on in winter approximatly 30 min prior starting, the sensors get
false readings,
the problem ist that the engine warning keeps on glowing, even if the
situation is cold again.
greetings from Germany
false readings,
i got the problem that you talking about. can you say what could it be?
deejaykaygee1
Jan 20, 2010 04:57 PM
augustin01
Jun 18, 2008 06:07 PM
skeeet
Oct 18, 2006 12:51 AM
