Engine "rattle"?
Old Sep 30, 2011 | 09:05 PM
  #31
SkinGripz's Avatar
Default Tow rings
Just got my H3 last week, and had a rattle at about 1000RPM and nowhere else. Knowing this was a resonance rattle didnt help calm my OCD. Tracked it to my front right D-Ring. Left was tight enough not to move unless you grabbed it and moved it, right would rattle all to hell in your hand. Had wife hold pedal at 1000RPM while I walked around the truck holding things. As soon as I grabbed the D-Ring, sound vanished. And it sounded like it was comming from behind the glovebox when driving in the vehicle. Nothing a socket wrench couldnt fix in 10 sexonds. Hope you get this lucky !!
Old Dec 9, 2012 | 02:49 PM
  #32
tnsplayer121's Avatar
Default 06 H3 Rattle
Originally Posted by ewilli
i have an 06 h3 with about 75k on it....mine sounds like a metal vibration on the passenger side in the front....almost like a skid plate is loose and vibrates on the frame but only at low RPM's. dealer thought it was the heat shield but they are removed and still have the problem. does not do it while sitting in the driveway, only when moving, which makes it a pain to figure out.
Ewilli, any remedy? My 06 H3 with the 64K + Miles on it is making the same noise it seems. I had it fixed once by a dealer in CO and it lasted about 10K miles. I need to figure the problem out as it seems to be getting worse over time. Any other suggestions? To better describe my noise it is rattle at lower RPS's and the sound is louder when going up hills and sounds like metal on metal.
Old Dec 9, 2012 | 09:32 PM
  #33
lex's Avatar
lex
my engine rattle turned out to be 4 broken bolts on the exhaust manifold and a huge crack in the manifold itself.
Old Dec 11, 2012 | 11:37 AM
  #34
Do you seriously think a guy that posted 1 time 2 years ago will respond????
Hummer2006h3
May 30, 2011 02:01 PM
nicos
Mar 26, 2008 03:31 PM
Daytona Hummer
Jan 23, 2008 11:28 AM
n0m4d
Dec 5, 2007 08:14 AM
kuda007
Nov 26, 2006 12:52 AM
