Help!! Engine rumble, shake, and rattle
Old Nov 25, 2006 | 09:49 PM
kuda007's Avatar
Default Help!! Engine rumble, shake, and rattle
I took my fuse box top off today, and blew out the dust in my fuse box. Now get this. After i put it back on (just blew air on the fuses) and I turned the car on, it sounded like it was choking, and was shaking back and forth. Now the engine light is on, and it's telling me that the Stability System is malfunctioning. The car is in limp-mode and i can only drive it about 20 mph. Any idea if I did somethign by accident in the fuse box? It's saturday and i'm looking at a tow.
Old Nov 25, 2006 | 09:52 PM
hummer plumber's Avatar
Default RE: Help!! Engine rumble, shake, and rattle
Check for a loose fuse
Old Nov 25, 2006 | 09:54 PM
kuda007's Avatar
Ok, gonna check now. **fingers crossed**
Old Nov 25, 2006 | 10:08 PM
kuda007's Avatar
Ok, for anyone that has had like 4 codes appear, and everything seem to "melt down" at once here is what I did, and so far it has fixed it.
I removed the fuse for the ABS system and the 4x4 for the rear. Numbers 29 and 30 on the fuse box. When i put them back in, the car started just fine. It was VERY dusty in there, so I'm thinking that when i used a compressor to blow the dust out, i must have shorted something in there. The engine light is still on, so i'm still going to take it in. Thanks for all the help.
Kuda
Old Nov 26, 2006 | 12:04 AM
Dennis's Avatar
It probably stored a code..Try cycling the ignition about 10 times (start and stop the engine)..Somewhere in that many times it should clear the code (if problem no longer exists)
Old Nov 26, 2006 | 12:36 AM
kuda007's Avatar
GRR it's back again. Either i still have a short some where in the fuse area, or the Stability system is now broken. Nothing left to do but tow to the dealer
Old Nov 26, 2006 | 12:52 AM
Dennis's Avatar
Go blow it off again..nothing to loose now..and wiggle all the fuses.
Raffi76
26
Feb 18, 2015 03:20 PM
lostsoul77
Oct 11, 2014 07:35 AM
Hummer2006h3
May 30, 2011 02:01 PM
psych0
Mar 20, 2010 10:05 AM
solarflare
Mar 24, 2008 02:14 AM
