Engine Code P2431
Old 05-16-2016, 11:30 AM
ChadB's Avatar
Default Engine Code P2431
Hey Guys,
When I start the old '07 H3 I get engine code P2431 which says "Secondary Air Injection System Pressure Sensor Performance." Apparently this reduces the hydrocarbon emissions during cold starts?? Really other than the light coming on and I turning it off with the code reader every time the vehicle doesn't drive or run any different at all, a few weeks ago it breezed through an Ontario emission test.
Do you think it's worth looking into or not a big deal?
Chad
Old 05-16-2016, 12:30 PM
It's not going to hurt anything driving it, you might just be a bigger polluter than you thought.
It could be a simple fix, you might have a bad MAP sensor, or a bad connection/wiring to it. Look around, locate the MAP, check the connection and wire harness leading to it. Take the connector off and clean it with some CRC Electrical contact cleaner, snap it back together. See what you find.
Old 05-16-2016, 12:34 PM
ChadB's Avatar
Thanks, I'll give it a look.
Old 05-22-2016, 09:11 PM
WR3NCHE4D's Avatar
Follow the Doctors advise. Start with the basics. If there was no light on during your Ontario Emission Test it will pass. The problem most likely showed up after the test. I would get the problem fixed. Colonel Sanders (A.K.A. Kathleen Wynne) is on a mission to reduce carbon emissions in Ontario. If you get pulled over the boys in blue, they can force another E-test even if you have a current pass report in your vehicle.
hummermongolia
10-04-2015 07:55 PM
Alex2012
10-01-2012 01:53 PM
sterlingmarlin30
01-31-2010 07:21 PM
therobesons
11-17-2009 08:49 PM
azz7772
01-10-2008 10:03 AM
Quick Reply: Engine Code P2431
