door hinge wear?
Old Mar 13, 2018 | 04:01 PM
Smokeshowin's Avatar
Default door hinge wear?
New 07 h3 owner. The 2 front doors on my rig require extra effort to open & close,(especially driver side). It was not in an accident. A friend owns a collision shop & said it's the "door check", simply a result of wear. Anyone have any thoughts or experience on this one? Thanks...
Old Mar 13, 2018 | 09:42 PM
happythree's Avatar
have you lubed the hinges regularly?
Old Mar 14, 2018 | 07:08 AM
I just got the vehicle, so I don't know about regular lubing. However, I did go around & spray w/ pb blaster.
Old Mar 14, 2018 | 09:36 AM
You sprayed w/ PB Blaster lube, or catalyst? The catalyst will remove old grease and eventually dry them out and make them worse. Make sure to use the lube. White Lithium Grease works well and lasts longer, PB Blaster makes some of that as well.
Old Mar 14, 2018 | 02:15 PM
Ordieh's Avatar
Hey Doc,
What is your opinion of GM SUPER LUBE. I have used it for a long time and have found it to be superb. A little pricey but I think worth it.
Old Mar 15, 2018 | 06:52 AM
I use the same 3in1 stuff I use on my garage door track, wheels, hinges, screw drive and spindles. It hasn't let me down yet and I like the "never lose" straw. Easy to direct the spray exactly where you want it!
Old Mar 16, 2018 | 10:51 AM
Originally Posted by Ordieh
Hey Doc,
Super Lube is good stuff, I have used that many times. My last can ran out like over a year ago, gotta find more one day.
One of my favs...
AverageWeekend
Sep 6, 2016 11:47 AM
Bakersdozen
Aug 11, 2013 04:37 PM
Xlr8n
Jun 20, 2012 03:24 PM
HummerGuy
Jul 24, 2007 03:03 PM
HummerGuy
Nov 12, 2006 05:44 AM
