Does this thing have Gremlins?
Old Jul 6, 2020 | 08:12 AM
Rachel h's Avatar
Default Does this thing have Gremlins?
We bought our 07 H3 in 2016 with 85K miles on it. We have had various issues with it, including having to replace the transmission twice in a year. Now, in the last 24 hours, the panic button has gone off twice with no one around, and, when we go out to check it, the radio is on. Our key fob was replaced in 2018 because the old one was worn out, so its not the keyfob.
Anyone have an idea what to look at next?
Old Jul 6, 2020 | 09:59 AM
Welcome to HF.
Does it have a sunroof?. If so, has the passenger side carpet gotten wet?
Are you still using the crappy azzed OEM Battery Terminal connectors?
Old Jul 6, 2020 | 06:14 PM
Rachel h's Avatar
Welcome to HF.
yes, to all those, but its been a while since the carpet has gotten wet
Old Jul 6, 2020 | 10:40 PM
You need to feed the gremlins. I recommend CRC
Old Jul 7, 2020 | 09:33 AM
Look up how to fix clogged sunroof drains and do that. Do NOT use any compressed air to blow out the drains, it doesn't work and will cause a bigger problem.
Then look into replacing the OEM Battery Terminal Connectors with a quality aftermarket set like Stingers or your favorite brand. It is supposed to be the FIRST Mod done to every H3/H3T, know problem makers.
Old Jul 8, 2020 | 06:05 AM
With the radio coming on.
Also check to see if your dome light goes off after you close the doors (keys out of the ignition).
You may have one or more of the door pin switches or the associated wiring to them acting up.
They are sometimes work intermittently and can set off the factory alarm. Pretty inexpensive to replace all 5 too.
Old Jul 8, 2020 | 06:19 AM
Banestudent21's Avatar
Care to post a link to the aftermarket Terminal connectors? Here I was thinking the sunroof drains were a day 1 mod to do
Old Jul 8, 2020 | 09:44 AM
Google search will bring you here... and about a bazillion more or so. I used Stinger SPT53302 and SPT53102 for both my 07 and 09, still on ebay.
Best Battery Terminals for my H3?
Ebay Stinger set
Old Jul 8, 2020 | 12:08 PM
therealdougkelly
Aug 4, 2020 02:35 PM
Cashville
Jan 19, 2012 09:59 PM
cryscor
Apr 11, 2009 12:38 PM
jrbnc
Feb 21, 2009 08:18 PM
TheJimer
17
Jun 2, 2007 05:18 PM
