Disengaging drive line/transmission
Old Oct 20, 2016 | 02:54 PM
phaseshifter69F's Avatar
Default Disengaging drive line/transmission
Last winter I started to drive my H3 on a wintery day and went about a mile or so and all movement stopped. It was like a manual transmission when you push in the clutch. Disengaging the driveline or transmission. I set for a few minutes and put the transmission back into Drive and the vehicle drove again for awhile but again disengaged. I since have driven the H3 and as long as the outside temperature is at least 45ish Degrees F, transmission/driveline will stay engaged and will drive just fine. During the winter when the problem was happening there was some fluid dropping fairly straight down where perhaps the problem exists. I have not gotten under the vehicle yet to observe and check it out. No apparent leakage during warmer weather. It does not seem as though the transmission is the issue. I have driven the vehicle during the spring, summer and fall a little this year but I think there is perhaps a solenoid/actuator that engages the driveline/transmission but have not found it yet on a schematic or diagram of the vehicle. Has anyone had a similar problem and please describe the issue, repair, and if you had someone repair or did you buy a part and replace the part yourself.
Old Oct 20, 2016 | 06:45 PM
650Hawk's Avatar
I had a similar problem with my wife's Tahoe. Turned out to be the Transfer case encoder motor. Sounds like it is shifting your transfer case into neutral.
Old Oct 20, 2016 | 08:22 PM
happythree's Avatar
you could try the buttons and see if anything changes,4hi,4hilock,4lo lock huh.
i exercize mine in a field monthly.
not a "mine field"...
Old Jan 10, 2017 | 08:40 PM
coolingman's Avatar
I'm experiencing the same thing....I think. it loses power to the wheels. Switching to 4WH everything is fine. I'm wondering if there is a sensor or solenoid that is affected when it gets wet, or a bare wire or something.
SafariHummerH2
Jun 9, 2016 12:12 PM
stinger95
Apr 30, 2016 05:54 PM
lockup7
Apr 5, 2016 04:33 PM
Eddie Omegax
Mar 15, 2016 09:56 PM
ReRun0007
Apr 26, 2015 12:52 PM
