disconnecting battery?
Old May 18, 2014 | 06:17 AM
a7m1's Avatar
Default disconnecting battery?
i need to disconnect my battery for anupcomming trip
i was wondering what do i need to worry about( reprogrammming and whatelse)
plwer windows
sunroof
radio( DOES IT NEED KEY CODE ???) i don't have the code
whatelse?
please post a brief instruction on what else to watch out from
Old May 18, 2014 | 07:34 AM
elkgrunt's Avatar
plwer windows
sunroof
whatelse?
Disconnect it, do what you have to do and reconnect it. Everything should be fine.
Old May 18, 2014 | 07:40 AM
a7m1's Avatar
thanks bro,
are you sure radio will not need keycode?
what are the precedure to reprogramming windows and sunroof?
thanks again.
Old May 18, 2014 | 09:40 AM
happythree's Avatar
you can leave it out forever, well not quite. then when you want to use your car again just reconnect it and add gas. then go where you want. it will work just like it did when it was built.
if you ever buy a new batt,its the same procedure.
Old May 18, 2014 | 11:27 AM
a7m1's Avatar
i really want to disconnect it to relearn everything idle, shift points whatever
as i just got the car and i don't really know how it was driven
does it affect the radio? will it ask me for a code??
Old May 18, 2014 | 11:43 AM
Derian06's Avatar
The only thing you have to do, is set the time again. It is literally that simple, I've probably disconnected my battery 12 times in the last 2 months, and everything is still working fine!
Old May 18, 2014 | 11:53 AM
a7m1's Avatar
thanks for the confirmation.
(do you think this will improve the drivability?)
my ****s are jerky little bit with what looks like slipping on slow acceleration
i don't know but it doesn't drive like our 05 trailblazer which is 2wd 4l60e
could 4wd makes little differenace?
is these transmissions adaptable to driving styles?
Old May 18, 2014 | 12:31 PM
to relearn fuel trims: disconnect battery, remove and clean maf sensor, remove and thoroughly clean tbi, reinstall and connect battery. GL
Old May 18, 2014 | 12:39 PM
a7m1's Avatar
thanks, but i wouldn't mess with my maf
i've cleaned maf sensors before with success using crc contact cleaner( is this safd to begin with? it has no oil residue and it evaporates instantly)
no things damaged but on vw maf it messed up with rubber gasket in the maf housing it bulged
anyhow the car air filter is kept clean and the engine is in good condition all of the mafs that i'vr cleaned before they are good to begin with and probably giving correct measurements
i'll clean throttle body but later on, would you recommend wd40 for this?
sorry but i still need confirmatiom
will the radio asks for code???? i am still paranoid
thanks
Old May 18, 2014 | 12:41 PM
a7m1's Avatar
what the longest period you had the battery disconnected?
